Salta al contenuto principale
ASUS Chromebook C100PA-RBRKT07 Battery Replacement
Cosa ti serve
  1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 2, immagine 1 di 1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the T5 screwdriver to remove the 6 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 4, immagine 1 di 1
    • Use the iFixit opening tool to pry the backing of the device off.
  5. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 5, immagine 1 di 1
    • Use the tweezers to separate the cables from the motherboard.
    • You need to reach inside and peel some tape to disconnect the wire.
  6. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 6, immagine 1 di 1
    • Use the JIS1 screwdriver to remove the four 2.1 mm screws around the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 7, immagine 1 di 2 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 7, immagine 2 di 2
    • Gently disconnect the audio cards, exposing the battery.
  8. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 8, immagine 1 di 1
    • Use the J00 screwdriver to remove the three 1.7 mm battery screws.
  9. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 9, immagine 1 di 3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 9, immagine 2 di 3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: passo 9, immagine 3 di 3
    • Grip the battery and remove it from the device.
    • Remove the battery cable out of the motherboard by lifting the battery cables.
Conclusione
Tiffany Foo
Membro da: 01/24/19
289 Reputazione
2 Guide realizzate
Cal Poly, Team S19-G4, White Winter 2019 Membro di Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 404
