Salta al contenuto principale
ASUS X540BA-BB61-CB Screen Replacement
Cosa ti serve
  1. ASUS  X540BA-BB61-CB Screen Replacement, Power Down the Laptop: passo 1, immagine 1 di 2 ASUS  X540BA-BB61-CB Screen Replacement, Power Down the Laptop: passo 1, immagine 2 di 2
    • Power off the device and unplug it from the charging cord.
  2. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel Frame: passo 2, immagine 1 di 2 ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel Frame: passo 2, immagine 2 di 2
    • Use a spudger to remove the plastic screw covers in the bottom right and left corner of the screen.
    • Remove the two Phillips #2 (M2.5 x4)mm flat head screws in the two bottom corners under the screw covers.
    • Then remove the bezel frame with a spudger.
  3. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel: passo 3, immagine 1 di 1
    • Once these screws are removed, carefully remove the bezel by the inner edge working your way around the perimeter.
    • Be careful to undo the clips as you remove the bezel and don't yank it off. The bezel is flexible but can break.
  4. ASUS  X540BA-BB61-CB Screen Replacement, Remove the grounding tape: passo 4, immagine 1 di 1
    • Remove the grounding tape covering the screws in the four corners of the screen.
    • Use a Phillips #2 screwdriver to remove four (M2 x 4) mm screws from the four corners of the screen that hold the LCD panel in place.
  5. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Screen: passo 5, immagine 1 di 1
    • Peel off one side of the tape and remove the two bottom screws.
    • It is important to remember that the video cable is secured with cleared tape.
    • Peel off the tape, gently slide the cable out and remove the LCD Panel. Take the new LCD panel and place it on the keyboard.
    • Gently slide the connector to the jack secured with cleared tape with both hands.
Conclusione
David Shodipo
Membro da: 01/14/22
1 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 69
Tutti i Tempi: 1,001
