Salta al contenuto principale
ASDA ES177 Steam Iron Power cord Replacement
Cosa ti serve
  1. ASDA ES177 Steam Iron Power cord Replacement, Disassembly: passo 1, immagine 1 di 3 ASDA ES177 Steam Iron Power cord Replacement, Disassembly: passo 1, immagine 2 di 3 ASDA ES177 Steam Iron Power cord Replacement, Disassembly: passo 1, immagine 3 di 3
    • Remove the security screw from the back panel.
    • Be cautious of any residual charge when disassembling.
  2. ASDA ES177 Steam Iron Power cord Replacement, Remove the back plate: passo 2, immagine 1 di 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the back plate: passo 2, immagine 2 di 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the back plate: passo 2, immagine 3 di 3
    • Insert a flathead screwdriver to pop off the back plate
  3. ASDA ES177 Steam Iron Power cord Replacement, Remove the cord from the holder: passo 3, immagine 1 di 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the cord from the holder: passo 3, immagine 2 di 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the cord from the holder: passo 3, immagine 3 di 3
    • Remove the retainer clamp by unscrewing the two Phillips screws.
  4. ASDA ES177 Steam Iron Power cord Replacement, Release the cord from the connector: passo 4, immagine 1 di 3 ASDA ES177 Steam Iron Power cord Replacement, Release the cord from the connector: passo 4, immagine 2 di 3 ASDA ES177 Steam Iron Power cord Replacement, Release the cord from the connector: passo 4, immagine 3 di 3
    • Remove the three flat-headed screws from the connector
  5. ASDA ES177 Steam Iron Power cord Replacement, Remove the plug: passo 5, immagine 1 di 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the plug: passo 5, immagine 2 di 3 ASDA ES177 Steam Iron Power cord Replacement, Remove the plug: passo 5, immagine 3 di 3
    • Unscrew the main screw to reveal the 3-core cable.
    • Remove the two screws that retain the cord in the plug.
  6. ASDA ES177 Steam Iron Power cord Replacement, Remove the rotator support: passo 6, immagine 1 di 1
    • Remove the rotator guide.
Conclusione
Altre 5 persone hanno completato questa guida.
honakrisi
Membro da: 01/28/20
3.946 Reputazione
8 Guide realizzate
7Commenti sulla guida
Saya blm menemukan penyelesaian
Rifqy Al firdaus - Replica
Thank you so much;
Vishal Sharma - Replica
Thank you so much
Thank you so much''
Thank you so much'''
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 60
Tutti i Tempi: 1,395
