Salta al contenuto principale
ARRIS Surfboard SB6183 Modem Heatsink Replacement
Cosa ti serve
  1. ARRIS Surfboard SB6183 Modem Heatsink Replacement, Heatsink: passo 1, immagine 1 di 3 ARRIS Surfboard SB6183 Modem Heatsink Replacement, Heatsink: passo 1, immagine 2 di 3 ARRIS Surfboard SB6183 Modem Heatsink Replacement, Heatsink: passo 1, immagine 3 di 3
    • Use pliers to remove the thin nut and washer from the coax port.
  2. ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 2, immagine 1 di 1
    • Remove the single 9mm Torx screw using a Torx T10 screwdriver.
  3. ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 3, immagine 1 di 3 ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 3, immagine 2 di 3 ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 3, immagine 3 di 3
    • Use a spudger to press the plastic retention clip inward and toward the center of the modem.
    • The plastic clip is hidden in a hole beneath the sticker on the bottom of the case.
  4. ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 4, immagine 1 di 3 ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 4, immagine 2 di 3 ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 4, immagine 3 di 3
    • Slide the left side panel of the modem toward the back, then up and out at a shallow angle.
  5. ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 5, immagine 1 di 3 ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 5, immagine 2 di 3 ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 5, immagine 3 di 3
    • There are small plastic tabs on either side of the clear LED diffuser. Use the flat end of a spudger to pry both of them outwards slightly.
  6. ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 6, immagine 1 di 2 ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 6, immagine 2 di 2
    • Rotate the diffuser upward to unlatch it.
    • You may need to hold the plastic tabs on either side out of the way.
  7. ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 7, immagine 1 di 2 ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 7, immagine 2 di 2
    • To remove the board, lift the front end up slightly and gently pull toward the front to remove.
    • You may need to wiggle the board loose from the thin clips on either side.
  8. ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 8, immagine 1 di 1
    • If your device doesn't have a heatsink, skip this step. To remove an existing heatsink, hold the board steady and use pliers to gently twist it off.
  9. ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 9, immagine 1 di 1
    • Peel off the paper backing that protects the thermally conductive adhesive to prepare the heatsink for application.
  10. ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 10, immagine 1 di 2 ARRIS Surfboard SB6183 Modem Heatsink Replacement: passo 10, immagine 2 di 2
    • Center the sticky side of the heatsink over the bare chip, then press down gently to secure it.
    • Make sure the heatsink is stuck in place and will not slide off.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Thank you for this review, helped me to open it. The only thing i did differently is peeled oof the sticker from the bottom - carefully, so not to damage it. Why do u place the heatsink on that specific tiny chip - is it the one that heats up the most? My feeling when opening it was that the RF part was the hottest.
Andru Nl - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 45
Tutti i Tempi: 3,080
