Salta al contenuto principale
APS Tech 101629 Channel Switch Replacement
Cosa ti serve
  1. APS Tech 101629 Channel Switch Replacement, External Casing: passo 1, immagine 1 di 3 APS Tech 101629 Channel Switch Replacement, External Casing: passo 1, immagine 2 di 3 APS Tech 101629 Channel Switch Replacement, External Casing: passo 1, immagine 3 di 3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Channel Switch Replacement: passo 2, immagine 1 di 2 APS Tech 101629 Channel Switch Replacement: passo 2, immagine 2 di 2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Channel Switch Replacement: passo 3, immagine 1 di 2 APS Tech 101629 Channel Switch Replacement: passo 3, immagine 2 di 2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Channel Switch Replacement: passo 4, immagine 1 di 1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Channel Switch Replacement: passo 5, immagine 1 di 2 APS Tech 101629 Channel Switch Replacement: passo 5, immagine 2 di 2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Channel Switch Replacement, Channel Switch: passo 6, immagine 1 di 2 APS Tech 101629 Channel Switch Replacement, Channel Switch: passo 6, immagine 2 di 2
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Channel Switch Replacement: passo 7, immagine 1 di 3 APS Tech 101629 Channel Switch Replacement: passo 7, immagine 2 di 3 APS Tech 101629 Channel Switch Replacement: passo 7, immagine 3 di 3
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
Conclusione
Alexis Weckel
Membro da: 04/11/11
140 Reputazione
3 Guide realizzate
Cal Poly, Team 24-60, Amido Spring 2011 Membro di Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 651
