Salta al contenuto principale
APEX AP-GS918 Speakers Replacement
Cosa ti serve
  1. APEX AP-GS918 Speakers Replacement, Power/Volume Button: passo 1, immagine 1 di 3 APEX AP-GS918 Speakers Replacement, Power/Volume Button: passo 1, immagine 2 di 3 APEX AP-GS918 Speakers Replacement, Power/Volume Button: passo 1, immagine 3 di 3
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
  2. APEX AP-GS918 Speakers Replacement: passo 2, immagine 1 di 3 APEX AP-GS918 Speakers Replacement: passo 2, immagine 2 di 3 APEX AP-GS918 Speakers Replacement: passo 2, immagine 3 di 3
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
  3. APEX AP-GS918 Speakers Replacement: passo 3, immagine 1 di 2 APEX AP-GS918 Speakers Replacement: passo 3, immagine 2 di 2
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
  4. APEX AP-GS918 Speakers Replacement, Speakers: passo 4, immagine 1 di 3 APEX AP-GS918 Speakers Replacement, Speakers: passo 4, immagine 2 di 3 APEX AP-GS918 Speakers Replacement, Speakers: passo 4, immagine 3 di 3
    • The speaker is attached to the bottom lid with with a small amount of glue and the wires are soldered to the motherboard.
    • In order to remove the speaker you will have to desolder the wires connected to the motherboard.
    • Start by peeling back the black electrical tape covering the motherboard components
    • You will also need to remove the black cloth tape covering the wire contact points.
  5. APEX AP-GS918 Speakers Replacement: passo 5, immagine 1 di 2 APEX AP-GS918 Speakers Replacement: passo 5, immagine 2 di 2
    • Now that the contacts are exposed, you can desolder them.
    • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
    • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
    • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
    • The speaker can now be removed. You may need to pull it with some force since there is a small bead of hot glue holding the speaker to its housing
Conclusione
USF Tampa, Team 9-1, Leahy Winter 2015 Membro di USF Tampa, Team 9-1, Leahy Winter 2015
USFT-LEAHY-W15S9G1
3 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 10
Tutti i Tempi: 173
