Salta al contenuto principale
AEG LM6000-U Lavazza A Modo Mio Disassembly
Cosa ti serve
  1. AEG LM6000-U  Lavazza A Modo Mio Disassembly, INtroduction: passo 1, immagine 1 di 2 AEG LM6000-U  Lavazza A Modo Mio Disassembly, INtroduction: passo 1, immagine 2 di 2
    • This guide is about taking apart this coffee maker. In my case the water flow stopped after running dry and a refill. After opening it up, water flow miraculously started to work again.
    • Taking it apart is fun, but not needed. You can just wait 30 min, and it will work again. (Maybe some thermal fuse is reset then).
  2. AEG LM6000-U  Lavazza A Modo Mio Disassembly, Removing screws: passo 2, immagine 1 di 3 AEG LM6000-U  Lavazza A Modo Mio Disassembly, Removing screws: passo 2, immagine 2 di 3 AEG LM6000-U  Lavazza A Modo Mio Disassembly, Removing screws: passo 2, immagine 3 di 3
    • The machine mainly hangs together with plastic clips. There are 5 screws:
    • 1. Right under the powercable guide on the bottom.
    • 2+3 Under the Lavazza brand plates on either side.
    • 4+5 On the handle, under the plastic cover caps.
  3. AEG LM6000-U  Lavazza A Modo Mio Disassembly, Pictures: passo 3, immagine 1 di 1
    • Top picture: valve and water pump below that.
  4. AEG LM6000-U  Lavazza A Modo Mio Disassembly: passo 4, immagine 1 di 2 AEG LM6000-U  Lavazza A Modo Mio Disassembly: passo 4, immagine 2 di 2
    • Heating element
    • PCB has useful labels .
Conclusione
Altre 2 persone hanno completato questa guida.
Mark
Membro da: 09/05/18
492 Reputazione
3 Guide realizzate
5Commenti sulla guida
Hi does anyone knows where is the thermoblock and if its easy to buy one on Modo Mio LM7000S-U (95007437700), Sometimes all lights flashing. I have to turn machine off and on again and if I am lucky it will work. AEG asked for £165 to repair it. Well I can buy a new one with thar money.
Manos - Replica
Hi Manos, did find a solution to your problem? I have the same issue and have bought a new machine but hoping to bring the old one back alive one day.
My understanding is that the thermoblock comes as part of the 'Brewing Unit' spare part purchasable from Electrolux, however it is listed as £133
martin riddell - Replica
Hi Manos,
How do you know it is the thermoblock.
Just thinking aloud: a thermoblock does not like something that sometimes works and sometimes doesn't.
Mark - Replica
My machine leaks water how do I get into it and is it an easy repair it the LM7000-U MODEL
Shaun - Replica
Is there a problem with newer batches of pods? I am seeing an increasing number where the coloured side of the pods is bending in so the machine can’t make proper holes - the resulting increased pressure makes its own hole, on the edge of the surface where the large holes should be, and coffee and grounds pour through this new hole.
Is it possible to post a picture on here?
Andrew Brown - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 194
Tutti i Tempi: 6,843
