Salta al contenuto principale
AEG Electrolux FM72 Disassembly for cleaning
Cosa ti serve
  1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: passo 1, immagine 1 di 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: passo 1, immagine 2 di 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: passo 1, immagine 3 di 3
    • Open the lid by pressing the grey button and lifting it away.
    • Clean each of the plastic parts with soap and water, and then leave them out to dry.
  2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: passo 2, immagine 1 di 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: passo 2, immagine 2 di 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: passo 2, immagine 3 di 3
    • Follow these steps to open the electronic casing.
    • Remove the four screws as shown in picture two.
    • A long Phillips screwdriver is needed for step two.
    • Remove the fifth screw at the bottom as shown in picture three.
  3. AEG Electrolux FM72 Disassembly for cleaning: passo 3, immagine 1 di 3 AEG Electrolux FM72 Disassembly for cleaning: passo 3, immagine 2 di 3 AEG Electrolux FM72 Disassembly for cleaning: passo 3, immagine 3 di 3
    • Gently pry the device open, using an iSesamo opener.
    • Now the I/O button can be removed.
    • Completely replacing this entire part requires desoldering wire connections.
  4. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: passo 4, immagine 1 di 2 AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: passo 4, immagine 2 di 2
    • Now the electronic components can be cleaned using an air compressor.
    • In picture one, you can see the PCBs. Under the PCB, you'll see blue batteries. These are 2 x 3 AA rechargeable batteries .
    • If the dust bag needs to be replaced, remove its securing screws.
Conclusione
Altre 3 persone hanno completato questa guida.
Kevin D
Membro da: 05/02/14
7.418 Reputazione
21 Guide realizzate
3Commenti sulla guida
Hello
How can i repair the electric wire on this device please ?
Heloise - Replica
Hallo
Which electric wire do you mean? Can you send in a picture? Does it need soldering?
Kind regards
Kevin
Kevin D - Replica
How can I disassemble the motor parts for cleaning?
wongkapo0611 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 55
Tutti i Tempi: 6,973
