Salta al contenuto principale
ACN Iris WG4K Video Screen Ribbon Cable Replacement
Cosa ti serve
  1. ACN Iris WG4K Video Screen Ribbon Cable Replacement, Handset: passo 1, immagine 1 di 2 ACN Iris WG4K Video Screen Ribbon Cable Replacement, Handset: passo 1, immagine 2 di 2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Video Screen Ribbon Cable Replacement, Lower Case: passo 2, immagine 1 di 1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 3, immagine 1 di 2 ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 3, immagine 2 di 2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 4, immagine 1 di 3 ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 4, immagine 2 di 3 ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 4, immagine 3 di 3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 5, immagine 1 di 2 ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 5, immagine 2 di 2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 6, immagine 1 di 1
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Video Screen Ribbon Cable Replacement, Blade Connector: passo 7, immagine 1 di 1
  8. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 8, immagine 1 di 1
    • Gently lift up on the upper case to separate it from the keypad/speaker panel.
  9. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 9, immagine 1 di 1
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (5 mm) located on the upper case.
  10. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 10, immagine 1 di 1
    • Rotate the top case 180 degrees so that the video screen is closest to you.
    • Lift up the bottom up so that it is perpendicular to the table (this helps you reach the two top screws).
    • The four Phillips head screws (6 mm) are highlighted by the red circles.
  11. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 11, immagine 1 di 1
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm).
  12. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 12, immagine 1 di 1
    • Flip the top case so that the video screen is facing up.
  13. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 13, immagine 1 di 1
    • Rotate the top case 180 degrees.
    • Gently lift up on the video screen and the blade and ribbon connector to give you more slack to work with.
  14. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 14, immagine 1 di 1
    • Place the video screen face down to expose the two screws. The screws are indicated by the red circles.
  15. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 15, immagine 1 di 2 ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 15, immagine 2 di 2
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (6 mm)
  16. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 16, immagine 1 di 2 ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 16, immagine 2 di 2
    • Pull the ribbon connector and blade connector through the top case.
  17. ACN Iris WG4K Video Screen Ribbon Cable Replacement, Video Screen Ribbon Cable: passo 17, immagine 1 di 1
    • Note that the video screen is no longer attached to the top case, place in on a flat surface.
    • Gently lift of the silver casing.
  18. ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 18, immagine 1 di 3 ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 18, immagine 2 di 3 ACN Iris WG4K Video Screen Ribbon Cable Replacement: passo 18, immagine 3 di 3
    • The two ribbon connectors are indicated by the red rectangles.
    • Disconnect the two ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull out the ribbon cables. Gently pull out the ribbon cables.
Conclusione
Itze Kenney
Membro da: 02/14/17
1.066 Reputazione
9 Guide realizzate
USF Tampa, Team 20-4, Remmell Spring 2017 Membro di USF Tampa, Team 20-4, Remmell Spring 2017
USFT-REMMELL-S17S20G4
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 252
