Salta al contenuto principale
ACN Iris WG4K Lower Case Replacement
Cosa ti serve
  1. ACN Iris WG4K Lower Case Replacement, Handset: passo 1, immagine 1 di 2 ACN Iris WG4K Lower Case Replacement, Handset: passo 1, immagine 2 di 2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Lower Case Replacement, Lower Case: passo 2, immagine 1 di 1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Lower Case Replacement: passo 3, immagine 1 di 2 ACN Iris WG4K Lower Case Replacement: passo 3, immagine 2 di 2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Lower Case Replacement: passo 4, immagine 1 di 3 ACN Iris WG4K Lower Case Replacement: passo 4, immagine 2 di 3 ACN Iris WG4K Lower Case Replacement: passo 4, immagine 3 di 3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Lower Case Replacement: passo 5, immagine 1 di 2 ACN Iris WG4K Lower Case Replacement: passo 5, immagine 2 di 2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Lower Case Replacement: passo 6, immagine 1 di 1
    • Gently lift up the lower case to separate it from the top case.
Conclusione
Itze Kenney
Membro da: 02/14/17
1.066 Reputazione
9 Guide realizzate
USF Tampa, Team 20-4, Remmell Spring 2017 Membro di USF Tampa, Team 20-4, Remmell Spring 2017
USFT-REMMELL-S17S20G4
4 Membri
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 9
Tutti i Tempi: 191
