Introduzione
The video screen ribbon cable is a part of the device used for transferring data between the keypad and the motherboard. Consider checking this guide before replacing the keypad, since you might just have a disconnected or faulty ribbon connector.
Cosa ti serve
Press upwards with your index finger on the 4P4C connector as shown in the image.
Pull the connector gently out of its socket.
Flip the main body of the video phone so that the bottom is facing up.
Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
