Introduzione
If your ABXY buttons or D-Pad have become unresponsive and remain so after being cleaned, the conductive sticker under them is likely worn out or damaged. Use this guide to replace the sticker and make your buttons work normally again
Cosa ti serve
Before starting the disassembly, remove
The stylus
Any game cartridge
The SD card
Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
Using a spudger, separate the back panel from the front casing by gently prying around the panel.
There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
Using a spudger, lift out the battery.
Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
There are 8 ribbon cables that need to be removed as shown in the picture.
For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
Flip the board over so the cartridge slot is on the bottom
Peel off the damaged sticker and replace it with the new one
ABXY buttons
D-pad
Altre 2 persone hanno completato questa guida.
