Salta al contenuto principale
AARP RealPad MA7BX2 Back Cover Replacement
Cosa ti serve
  1. AARP RealPad MA7BX2 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 2 AARP RealPad MA7BX2 Back Cover Replacement, Back Cover: passo 1, immagine 2 di 2
    • Loosen the back cover using the suction cup.
    • Pull up on the center of the back with the suction cup.
    • Pull up on all four corners of the back with the suction cup.
  2. AARP RealPad MA7BX2 Back Cover Replacement: passo 2, immagine 1 di 1
    • Remove the back cover by gently placing the small opening tool in the crevice created by loosening the back.
    • Slide the opening tool around the edges of the device.
    • Wedge it open using the opening tool.
    • Use the suction cup again if you're having trouble removing the back cover.
  3. AARP RealPad MA7BX2 Back Cover Replacement: passo 3, immagine 1 di 2 AARP RealPad MA7BX2 Back Cover Replacement: passo 3, immagine 2 di 2
    • The black tape is stuck to delicate wires; remove with caution.
    • Peel off the silver tape.
    • Gently pull off the black tape.
  4. AARP RealPad MA7BX2 Back Cover Replacement: passo 4, immagine 1 di 2 AARP RealPad MA7BX2 Back Cover Replacement: passo 4, immagine 2 di 2
    • Using a JIS #000 screwdriver, remove the two 2.5 mm screws.
  5. AARP RealPad MA7BX2 Back Cover Replacement: passo 5, immagine 1 di 2 AARP RealPad MA7BX2 Back Cover Replacement: passo 5, immagine 2 di 2
    • Lift off the black audio cover.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 801
