Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will show you how to replace the joystick component on the 8Bitdo N30 Arcade Stick.
  1. Turn the device over so that the bottom is facing up. Turn the device over so that the bottom is facing up.
    • Turn the device over so that the bottom is facing up.
  2. Use a Phillips screwdriver to unscrew all 10 of the 3 mm screws on the back plate.
    • Use a Phillips screwdriver to unscrew all 10 of the 3 mm screws on the back plate.
  3. Remove the rubber slider as indicated in the picture to assist in removing the back panel. Hold the arcade stick and pry the back panel away from the device until it comes off.
    • Remove the rubber slider as indicated in the picture to assist in removing the back panel.
    • Hold the arcade stick and pry the back panel away from the device until it comes off.
    • Remember that you will later be putting the rubber slider back in, before the back panel.
  4. Locate the back piece of the joystick. Unscrew the 4 screws that secure the joystick to the plate with the Philips crosshead screwdriver.
    • Locate the back piece of the joystick.
    • Unscrew the 4 screws that secure the joystick to the plate with the Philips crosshead screwdriver.
  5. Use a flathead screwdriver to unscrew the middle screw that holds the ball piece onto the joystick. Remove the ball piece and set it aside.
    • Use a flathead screwdriver to unscrew the middle screw that holds the ball piece onto the joystick.
    • Remove the ball piece and set it aside.
    • Be sure to hold the ball piece in place while turning the screw left, or counterclockwise.
    • When attaching the new joystick and ball piece, turn the screw to the right, or clockwise while holding the ball piece in place.
  6. Locate the joystick wires that are attached to the four indicated plugs on the motherboard, and remove them. In fine print, "left", "down", "up", and "right" are found above the wires that need to be removed. Take caution and gently disconnect the wires.
    • Locate the joystick wires that are attached to the four indicated plugs on the motherboard, and remove them.
    • In fine print, "left", "down", "up", and "right" are found above the wires that need to be removed.
    • Take caution and gently disconnect the wires.
  7. Remove the back piece from the mounting plate. Remembering that the four slots indicated is where you will be screwing in the new joystick's back piece.
    • Remove the back piece from the mounting plate.
    • Remembering that the four slots indicated is where you will be screwing in the new joystick's back piece.
Conclusione
For the new joystick, follow the steps in reverse order. Once again, don’t forget the rubber slider for the back panel.
Boot up your favorite PC or Nintendo Switch fighting game and make sure your joystick works!
looks just like the mayflash f300
Jon Hernandez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 31
Tutti i Tempi: 478
