Salta al contenuto principale
4x4 Speed Cube Broken Piece Fix and Assembly
Cosa ti serve
  1. 4x4 Speed Cube Broken Piece Fix and Assembly, 4x4 Speed Cube: passo 1, immagine 1 di 2 4x4 Speed Cube Broken Piece Fix and Assembly, 4x4 Speed Cube: passo 1, immagine 2 di 2
    • Using a wooden toothpick, take a dollop of E6000 industrial strength adhesive and apply it to the broken piece.
    • E6000 contains perchloroethylene which can emit harmful vapors. Only use this adhesive in a well ventilated area.
    • E6000 is not required for this fix, any strong adhesive will work.
  2. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 2, immagine 1 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 2, immagine 2 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 2, immagine 3 di 3
    • Press the pieces together while applying light pressure.
    • Ensure that the pieces are aligned properly. Compare with a similar piece of the speed cube to double check alignment.
    • Allow the E6000 adhesive to fully cure for 24 to 72 hours.
  3. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 3, immagine 1 di 2 4x4 Speed Cube Broken Piece Fix and Assembly: passo 3, immagine 2 di 2
    • Once dry, sand the piece so that it is smooth, ensuring that little to no glue residue is left on the surface.
    • Now you are ready to reassemble the speed cube!
  4. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 4, immagine 1 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 4, immagine 2 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 4, immagine 3 di 3
    • Locate the top and side central screws of the inner core.
    • Loosen the top and side central screws.
    • Avoid over loosening the screws as it may result in pieces falling out of the core.
  5. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 5, immagine 1 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 5, immagine 2 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 5, immagine 3 di 3
    • Stack all three edge bracket pieces with the large bracket piece in the middle.
    • Insert the stacked bracket pieces in to the center of the core.
    • You may need to exert some force in order to insert this piece.
  6. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 6, immagine 1 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 6, immagine 2 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 6, immagine 3 di 3
    • Insert the colored center pieces directly into the grooves of the core's central edge bracket
    • Ensure that the color of the inserted pieces matches the color of the surrounding pieces.
  7. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 7, immagine 1 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 7, immagine 2 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 7, immagine 3 di 3
    • Insert the corner colored pieces into the grooves on either side of the center colored pieces.
  8. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 8, immagine 1 di 2 4x4 Speed Cube Broken Piece Fix and Assembly: passo 8, immagine 2 di 2
    • Insert the colored center pieces into the grooves on top of the core's central edge bracket.
  9. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 9, immagine 1 di 2 4x4 Speed Cube Broken Piece Fix and Assembly: passo 9, immagine 2 di 2
    • Insert the colored corner pieces into the grooves on either side of the central colored pieces.
    • The speed cube should now have 3 rows and 4 columns completed on both sides with missing pieces.
  10. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 10, immagine 1 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 10, immagine 2 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 10, immagine 3 di 3
    • Insert the corner edge piece into the grooves of the correct corresponding corner.
    • Ensure that the colors of the inserted piece matches the colors of the 3 sides.
    • You may need to exert some force to properly insert this piece.
    • Repeat the above step with the opposing corner.
  11. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 11, immagine 1 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 11, immagine 2 di 3 4x4 Speed Cube Broken Piece Fix and Assembly: passo 11, immagine 3 di 3
    • Pull the corner piece apart until there is ample room to slide the edge piece in
    • Carefully insert the corresponding edge piece into the groove of the edge bracket
    • Repeat the steps for the other edge piece
    • You may need to exert some force to properly insert these pieces.
  12. 4x4 Speed Cube Broken Piece Fix and Assembly: passo 12, immagine 1 di 2 4x4 Speed Cube Broken Piece Fix and Assembly: passo 12, immagine 2 di 2
    • Pull apart both halves of the cube until the screw in the core is visible
    • Tighten the screw with a screwdriver until the speed cube rotates with the desired smooth motion
    • Repeat for as many sides as needed
Conclusione
Test the speed cube out. If the cube rotates smoothly then you have done the repair correctly! If the cube requires some force to rotate then you may need to loosen the screws of the core.
If more pieces have popped off, the process for reassembly of the pieces back into the speed cube's core is similar to steps 4 to 7 detailed in this guide. However, if more or different pieces of the core fall out or get damaged then the guide may not work as intended.
UC Davis, Team 1-1, Morris Winter 2024 Membro di UC Davis, Team 1-1, Morris Winter 2024
UCD-MORRIS-W24S1G1
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 52
Tutti i Tempi: 429
