Salta al contenuto principale
4-Stroke Small Gas Engine Spark Plug Replacement
Cosa ti serve
  1. 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: passo 1, immagine 1 di 3 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: passo 1, immagine 2 di 3 4-Stroke Small Gas Engine Spark Plug Replacement, Spark Plug: passo 1, immagine 3 di 3
    • Tug the Spark Plug Cap from the top of the Spark Plug (between the OHV housing and the exhaust manifold) with your hands to remove it.
  2. 4-Stroke Small Gas Engine Spark Plug Replacement: passo 2, immagine 1 di 2 4-Stroke Small Gas Engine Spark Plug Replacement: passo 2, immagine 2 di 2
    • Make sure the engine is turned off and cool to the touch before completing this step.
    • Using a ¼ “ socket and Handheld Ratchet, loosen the three screws holding the Exhaust Manifold Heat Shield on.
  3. 4-Stroke Small Gas Engine Spark Plug Replacement: passo 3, immagine 1 di 3 4-Stroke Small Gas Engine Spark Plug Replacement: passo 3, immagine 2 di 3 4-Stroke Small Gas Engine Spark Plug Replacement: passo 3, immagine 3 di 3
    • Once the Heat Shield is removed, grip the Spark Plug’s threaded diameter with an Adjustable wrench and rotate counterclockwise.
    • Alternatively, you may use a 5/8" wrench or 5/8" deep socket along with a handheld ratchet.
    • Remove the Champion RC12YC Spark Plug from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Jack Linchey
Membro da: 04/19/18
277 Reputazione
2 Guide realizzate
Cal Poly, Team S25-G15, Maness Spring 2018 Membro di Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 83
Tutti i Tempi: 1,287
