Salta al contenuto principale
4-Stroke Small Gas Engine Air Filter Replacement
Cosa ti serve
  1. 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: passo 1, immagine 1 di 3 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: passo 1, immagine 2 di 3 4-Stroke Small Gas Engine Air Filter Replacement, Air Filter: passo 1, immagine 3 di 3
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. 4-Stroke Small Gas Engine Air Filter Replacement: passo 2, immagine 1 di 1
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
Conclusione
Altre 2 persone hanno completato questa guida.
Ethan Narad
Membro da: 04/19/18
529 Reputazione
3 Guide realizzate
Cal Poly, Team S25-G15, Maness Spring 2018 Membro di Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 633
