Introduzione
So you've got a new shell for your 3DS XL and want your SD cover to be the same color as your device? Follow this guide to have it done in 10 - 15 minutes, with minor disassembly.
If you have a stylus, SD card or a game cartridge in the console, take them out
Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover
The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
Remove the six 6.2 mm screws using a Phillips #00 screwdriver
Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #00 screwdriver.
With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
Completely remove the upper case from the rest of the device and set aside.
Remove the 3 golden, 2.3 mm screws located around the stylus slot with a Phillips #00 screwdriver.
Altre 2 persone hanno completato questa guida.
