Salta al contenuto principale
3DR Solo Propeller Disassembly
  1. 3DR Solo Propeller Disassembly, Propeller: passo 1, immagine 1 di 1
    • Grip the arm, which is located underneath the propeller, with one hand, and with your dominant hand grip the center of the propeller.
  2. 3DR Solo Propeller Disassembly: passo 2, immagine 1 di 1
    • Twist the propeller from the locked to unlocked position as indicated by the images of the lock.
    • You will need to twist in this direction for 2-3 full rotations before the propeller will detach.
  3. 3DR Solo Propeller Disassembly: passo 3, immagine 1 di 1
    • Lift the propeller off the motor.
    • To remove the silver-top propellers, repeat these steps, turning the propellers in the opposite direction of the black-top propellers.
Conclusione
Lauren Hays
Membro da: 09/11/17
222 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 606
