Salta al contenuto principale
3DR Iris Plus Quadcopter Gimbal Removal Procedure
Cosa ti serve
  1. 3DR Iris Plus Quadcopter Gimbal Removal Procedure, Gimbal: passo 1, immagine 1 di 3 3DR Iris Plus Quadcopter Gimbal Removal Procedure, Gimbal: passo 1, immagine 2 di 3 3DR Iris Plus Quadcopter Gimbal Removal Procedure, Gimbal: passo 1, immagine 3 di 3
    • If your drone is equipped with it, remove the video transmitter.
    • Disconnect all cables from the gimbal.
    • If your drone has neither the gimbal or video transmitter, you can skip this step.
  2. 3DR Iris Plus Quadcopter Gimbal Removal Procedure: passo 2, immagine 1 di 2 3DR Iris Plus Quadcopter Gimbal Removal Procedure: passo 2, immagine 2 di 2
    • Unscrew the 16 mm screw attaching the gimbal mount to the body of the drone using the 3 mm Hex screwdriver/key.
  3. 3DR Iris Plus Quadcopter Gimbal Removal Procedure: passo 3, immagine 1 di 2 3DR Iris Plus Quadcopter Gimbal Removal Procedure: passo 3, immagine 2 di 2
    • Rotate the drone 180 degrees.
    • Unscrew the other 16mm gimbal mount screw using the 3 mm Hex screwdriver/key.
  4. 3DR Iris Plus Quadcopter Gimbal Removal Procedure: passo 4, immagine 1 di 1
    • Remove the gimbal mount from the body of the drone.
Conclusione
Evan Witulski
Membro da: 02/10/20
349 Reputazione
3 Guide realizzate
Cal Poly, Team S7-G5, Regan Winter 2020 Membro di Cal Poly, Team S7-G5, Regan Winter 2020
CPSU-REGAN-W20S7G5
5 Membri
9 Guide realizzate
Un commento
Where are the two wires connect to the gimbal one is a ground and the white wire connects to the power, but where?
James Reed - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 12
Tutti i Tempi: 205
