Salta al contenuto principale
360fly 4K Lens Replacement
Cosa ti serve
  1. 360fly 4K Lens Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. 360fly 4K Lens Replacement: passo 2, immagine 1 di 1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
    In the older model for Fly360 camera, the screws are PH000.
    Renjamin - Replica
    In the old 360Fly HD camera, the screw requires a #00 Philips head screwdriver. Unfortunately for me, one of the screws on mine was torqued down a bit too tight, that I ended up stripping the screw head trying to loosen it by hand.
    XzTS - Replica
  3. 360fly 4K Lens Replacement: passo 3, immagine 1 di 2 360fly 4K Lens Replacement: passo 3, immagine 2 di 2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  4. 360fly 4K Lens Replacement: passo 4, immagine 1 di 1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
  5. 360fly 4K Lens Replacement: passo 5, immagine 1 di 2 360fly 4K Lens Replacement: passo 5, immagine 2 di 2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
  6. 360fly 4K Lens Replacement: passo 6, immagine 1 di 3 360fly 4K Lens Replacement: passo 6, immagine 2 di 3 360fly 4K Lens Replacement: passo 6, immagine 3 di 3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
    Do I have to remove the battery to replace the SD card?
    BoB - Replica
  7. 360fly 4K Lens Replacement, SD Card: passo 7, immagine 1 di 1
    • Gently pry the plug from the motherboard and remove the motherboard from the assembly.
  8. 360fly 4K Lens Replacement: passo 8, immagine 1 di 1
    • Remove the three 3 mm screws from the circuit assembly with a T4 screwdriver.
  9. 360fly 4K Lens Replacement: passo 9, immagine 1 di 1
    • Gently pry out the plug from the circuit assembly.
  10. 360fly 4K Lens Replacement: passo 10, immagine 1 di 1
    • Press and release the SD card to remove it from the circuit assembly.
    Does anyone know how large a card the 360fly can support? I’d like to put a 256gb card in if it will support it.
    BoB - Replica
  11. 360fly 4K Lens Replacement, Lens: passo 11, immagine 1 di 1
    • Unscrew the five 3mm screws with a T4 screwdriver.
  12. 360fly 4K Lens Replacement: passo 12, immagine 1 di 1
    • Gently push against the lens module to remove it from the 360fly 4K assembly.
    Boa Tarde...  Resido no Brasil a lente da minha FLY 360 4k Foi danificada onde consigo uma lente de reposição ?
    thiagoboesingg - Replica
Conclusione
Jacob Herron
Membro da: 11/08/17
463 Reputazione
3 Guide realizzate
IUPUI, Team S5-G3, Baechle Fall 2017 Membro di IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 Membri
3 Guide realizzate
4 Commenti
Hi. Where to get a replacement lens as I am in need for this repair, but 360fly offer a full service for $150 and do not sell spare lenses. Thx
anguel nakov - Replica
There is no info where to buy the replacement lens.
gelo3000 - Replica
Anyone know about usb pinout? I lost my charger adapter
Nuri Can PEHLİVAN - Replica
Hi.
I inadvertently found your question.
I have this same problem.
I've lost the charger, too, and now I'm looking for a chance to charge without a base, or a chance to buy a base.
Imants
Imants R -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,578
