Introduzione
If your WORX 20V Power Share GT 3.0 12" String Trimmer (Model WG163M) stops cutting grass effectively or the trimmer line has worn out, use this guide to replace the trimmer spool.
The trimmer spool is the component that feeds trimmer line through the trimmer head. As the trimmer operates, the spinning line cuts grass and weeds. Over time, the line becomes shorter, breaks, or runs out completely. This happens when the trimmer line rubs against abrasive surfaces causing friction, hits solid objects, or faces an excessive load of grass/weeds. Replacing the spool restores the trimmer’s cutting ability and allows the tool to function normally again.
Common symptoms of a worn or empty spool include the trimmer not cutting grass, and little or no line extending from the trimmer head.
Before you begin this repair, make sure the battery is disconnected. Failure to do so may result in serious injury.
Cosa ti serve
Press and hold down the large orange button on the top of the battery.
While holding the orange button, firmly slide the battery down the handguard of the trimmer to disconnect it.
Without unraveling the entire spool, grab the loose trimmer line from your replacement trimmer spool.
Starting from the inside of the trimmer housing, thread about 2 inches of trimmer line through the hole on the side of the housing.
Continue to thread the line without unwinding it until you reach your trimmer spool.
Push the spool down into place once it reaches the spool housing.
Your trimmer should now function normally, easily cutting through grass and weeds until its time for the next spool replacement.
