Salta al contenuto principale
2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement
Cosa ti serve
  1. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 1 di 1
    • Open the glove compartment in the passenger seat area.
    • The cabin air filter is located behind the glove compartment.
  2. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 2, immagine 1 di 2 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 2, immagine 2 di 2
    • Carefully detach the support bar from the glove compartment.
  3. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 3, immagine 1 di 2 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 3, immagine 2 di 2
    • On the side on the glove compartment there is a sign to push inward.
    • Use both hands to push inward to release the plastic holders on both sides.
    • Carefully lower the glove compartment down.
  4. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 4, immagine 1 di 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 4, immagine 2 di 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 4, immagine 3 di 3
    • You will have access to the filter compartment and cover.
    • Pinch the right side of the filter cover and pull toward you; it should come out with ease.
    • Be aware of the signs on the cover when replacing it in Steps 7-9.
  5. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 5, immagine 1 di 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 5, immagine 2 di 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 5, immagine 3 di 3
    • Pull the compartment completely out.
  6. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 6, immagine 1 di 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 6, immagine 2 di 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 6, immagine 3 di 3
    • Pull out the old filter from the compartment.
  7. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 7, immagine 1 di 2 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 7, immagine 2 di 2
    • Grab your new filter and place it into the compartment.
    • On the side of the filter, there are signs of the direction the filter should be placed in the direction of airflow. If placed incorrectly, your A/C will not filter the air well.
    • Pinch to adjust the filter in the compartment.
  8. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 8, immagine 1 di 2 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 8, immagine 2 di 2
    • Insert the compartment back into the filter compartment.
    • Make sure you put the compartment upwards in the direction the arrow is pointing.
  9. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 9, immagine 1 di 2 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 9, immagine 2 di 2
    • Place the cover back on the filter compartment.
    • Follow the arrow to appropriately place the cover in place.
  10. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 10, immagine 1 di 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 10, immagine 2 di 3 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 10, immagine 3 di 3
    • Do not forget to attach the support bar back to the glove compartment.
    • You can close the glove compartment. The plastic holders should click back to place.
  11. 2019-2024 Toyota RAV4 XLE Hybrid Cabin Air Filter Replacement: passo 11, immagine 1 di 1
    • You have finally replaced the cabin air filter!
Conclusione
By the end of this guide you have successfully replaced the cabin air filter on a 2023 RAV4 XLE Hybrid. Enjoy your clean air!
Altre 2 persone hanno completato questa guida.
Bryan Huinac
Membro da: 01/24/23
247 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 130
Ultimi 30 Giorni: 390
Tutti i Tempi: 1,705
