Salta al contenuto principale
2021 Honda HR-V Rear Signal Light Bulb Replacement
Cosa ti serve
  1. 2021 Honda HR-V Rear Signal Light Bulb Replacement, Rear Signal Light Bulb: passo 1, immagine 1 di 1
    • Press the tailgate release button and lift open the rear hatch.
  2. 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 2, immagine 1 di 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 2, immagine 2 di 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 2, immagine 3 di 3
    • Remove the two screws beside each tail light assembly (four total) using a Phillips #1 screwdriver.
  3. 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 3, immagine 1 di 2 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 3, immagine 2 di 2
    • Place both hands on the tail light assembly and pull it directly outwards (away from the vehicle).
    • The tail light assembly will still be connected to the vehicle by wiring, so make sure to be careful when pulling the light assembly out.
  4. 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 4, immagine 1 di 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 4, immagine 2 di 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 4, immagine 3 di 3
    • Remove the rear signal light bulb from the light assembly by rotating the bulb socket counterclockwise.
  5. 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 5, immagine 1 di 2 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 5, immagine 2 di 2
    • Pull apart the light bulb from its socket.
    • Replace with a new light bulb and apply pressure to ensure the light bulb is securely fastened.
  6. 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 6, immagine 1 di 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 6, immagine 2 di 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: passo 6, immagine 3 di 3
    • Slide the light assembly into the raised white plastic attached to the vehicle.
    • Align the holes on the light assembly to the holes on the vehicle and fasten the bolts into position.
Linea Traguardo
Guadalupe Guevara
Membro da: 10/26/22
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 52
Tutti i Tempi: 1,214
