Salta al contenuto principale
2021 Chevrolet Silverado Tail Light Replacement
Cosa ti serve
  1. 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: passo 1, immagine 1 di 3 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: passo 1, immagine 2 di 3 2021 Chevrolet Silverado Tail Light Replacement, Tail Light: passo 1, immagine 3 di 3
    • Open the tailgate.
    • Remove the top and bottom T15 screws from each side of the tail lights.
    • Gently remove the tail lights by pulling outward.
  2. 2021 Chevrolet Silverado Tail Light Replacement: passo 2, immagine 1 di 3 2021 Chevrolet Silverado Tail Light Replacement: passo 2, immagine 2 di 3 2021 Chevrolet Silverado Tail Light Replacement: passo 2, immagine 3 di 3
    • Unplug the sockets and remove the reverse light bulb from the tail light.
  3. 2021 Chevrolet Silverado Tail Light Replacement: passo 3, immagine 1 di 3 2021 Chevrolet Silverado Tail Light Replacement: passo 3, immagine 2 di 3 2021 Chevrolet Silverado Tail Light Replacement: passo 3, immagine 3 di 3
    • Plug the brake lights connector.
    • Twist and secure the socket tightly.
    • Plug in the turn signal bulb connector. Twist and secure tightly.
  4. 2021 Chevrolet Silverado Tail Light Replacement: passo 4, immagine 1 di 3 2021 Chevrolet Silverado Tail Light Replacement: passo 4, immagine 2 di 3 2021 Chevrolet Silverado Tail Light Replacement: passo 4, immagine 3 di 3
    • Plug in the parking lights connector. Twist and secure the socket tightly.
    • Plug in the TURN SIGNALS connector. Please follow the same steps for the other side of the tail lights.
    • Make sure all the connections are plugged and tight. Also ensure that the caps are sealed.
  5. 2021 Chevrolet Silverado Tail Light Replacement: passo 5, immagine 1 di 2 2021 Chevrolet Silverado Tail Light Replacement: passo 5, immagine 2 di 2
    • First, remove the reverse light bulb from the vehicle.
    • Then, connect the socket to the reverse light connector from the new tail light.
  6. 2021 Chevrolet Silverado Tail Light Replacement: passo 6, immagine 1 di 3 2021 Chevrolet Silverado Tail Light Replacement: passo 6, immagine 2 di 3 2021 Chevrolet Silverado Tail Light Replacement: passo 6, immagine 3 di 3
    • Lastly, plug the vehicle’s tail light socket to new tail light connector.
  7. 2021 Chevrolet Silverado Tail Light Replacement: passo 7, immagine 1 di 3 2021 Chevrolet Silverado Tail Light Replacement: passo 7, immagine 2 di 3 2021 Chevrolet Silverado Tail Light Replacement: passo 7, immagine 3 di 3
    • Gently push the tail light into the mounting position and use T15 screwdriver to tighten the top and bottom screws.
    • Repeat the same process for the other side of the tail light.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 146
Tutti i Tempi: 1,495
