Salta al contenuto principale
2019 Toyota Highlander Cabin Air Filter Replacement
  1. 2019 Toyota Highlander Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 1 di 2 2019 Toyota Highlander Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 2 di 2
    • Open the glove compartment and take everything out.
  2. 2019 Toyota Highlander Cabin Air Filter Replacement: passo 2, immagine 1 di 3 2019 Toyota Highlander Cabin Air Filter Replacement: passo 2, immagine 2 di 3 2019 Toyota Highlander Cabin Air Filter Replacement: passo 2, immagine 3 di 3
    • Press the tabs on the sides of the glove compartment until they are released.
    • Please press the sides gently to avoid any damage.
  3. 2019 Toyota Highlander Cabin Air Filter Replacement: passo 3, immagine 1 di 1
    • Once the tabs are released, remove the entire glove compartment.
  4. 2019 Toyota Highlander Cabin Air Filter Replacement: passo 4, immagine 1 di 3 2019 Toyota Highlander Cabin Air Filter Replacement: passo 4, immagine 2 di 3 2019 Toyota Highlander Cabin Air Filter Replacement: passo 4, immagine 3 di 3
    • Open the second cover. Position your finger where the red circle is pointing in the first image, then lower it.
  5. 2019 Toyota Highlander Cabin Air Filter Replacement: passo 5, immagine 1 di 3 2019 Toyota Highlander Cabin Air Filter Replacement: passo 5, immagine 2 di 3 2019 Toyota Highlander Cabin Air Filter Replacement: passo 5, immagine 3 di 3
    • Press the tabs on the side of the third cover. Remove the cover.
    • Do not apply heavy force to prevent damage.
  6. 2019 Toyota Highlander Cabin Air Filter Replacement: passo 6, immagine 1 di 3 2019 Toyota Highlander Cabin Air Filter Replacement: passo 6, immagine 2 di 3 2019 Toyota Highlander Cabin Air Filter Replacement: passo 6, immagine 3 di 3
    • Pull the filter out. If the filter is really dirty, then replace it with a new one. Otherwise, clean the filter and return it to position.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 54
Ultimi 30 Giorni: 220
Tutti i Tempi: 4,903
