Salta al contenuto principale
2018-Present Toyota Corolla Engine Air Filter Replacement
Cosa ti serve
  1. 2018-Present Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: passo 1, immagine 1 di 2 2018-Present Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: passo 1, immagine 2 di 2
    • Park your Toyota corolla on a flat surface. Turn off engine. Remove keys from ignition.
    • Open the hood after the engine is cool.
  2. 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 2, immagine 1 di 3 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 2, immagine 2 di 3 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 2, immagine 3 di 3
    • Lift and secure the hood.
  3. 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 3, immagine 1 di 3 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 3, immagine 2 di 3 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 3, immagine 3 di 3
    • Unclip the housing clip to open the housing.
  4. 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 4, immagine 1 di 3 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 4, immagine 2 di 3 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 4, immagine 3 di 3
    • Unclip the housing's second clip on the other side of the housing.
  5. 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 5, immagine 1 di 2 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 5, immagine 2 di 2
    • Lift the housing.
  6. 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 6, immagine 1 di 2 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 6, immagine 2 di 2
    • Remove the old air filter by gently taking the filter out from under the housing.
  7. 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 7, immagine 1 di 2 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 7, immagine 2 di 2
    • Install the new air filter by placing it into the housing.
    • Check to make sure it is properly oriented with the rubber rim facing up.
  8. 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 8, immagine 1 di 2 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 8, immagine 2 di 2
    • Close the housing.
  9. 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 9, immagine 1 di 3 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 9, immagine 2 di 3 2018-Present Toyota Corolla Engine Air Filter Replacement: passo 9, immagine 3 di 3
    • Resecure the clips on both sides of the housing.
Conclusione
Final Checks:
  • Check to ensure that the housing is clipped securely in its place.
  • Start your vehicle to ensure that it is running smoothly.
  • Check dashboard to ensure there is no warning light flashing.
Quoc Nguyen
Membro da: 02/02/24
169 Reputazione
1 Guida realizzata
UC Davis, Team 2-7, Andersen Winter 2024 Membro di UC Davis, Team 2-7, Andersen Winter 2024
UCD-ANDERSEN-W24S2G7
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 49
Tutti i Tempi: 94
