Salta al contenuto principale
2018 Yamaha YZ 250f Chain Replacement
Cosa ti serve
  1. 2018 Yamaha YZ 250f Chain Replacement, Chain: passo 1, immagine 1 di 2 2018 Yamaha YZ 250f Chain Replacement, Chain: passo 1, immagine 2 di 2
    • Place the dirtbike on a stand.
    • Ensure that the proper stand is being used as the bike may become unstable.
  2. 2018 Yamaha YZ 250f Chain Replacement: passo 2, immagine 1 di 1
    • Shift the gear lever into its neutral position so that the rear wheel spins freely.
    • Neutral is between first and second gear.
  3. 2018 Yamaha YZ 250f Chain Replacement: passo 3, immagine 1 di 1
    • Locate the master-link on the chain.
    • The master-link has a safety clip on it in the shape of a C.
  4. 2018 Yamaha YZ 250f Chain Replacement: passo 4, immagine 1 di 3 2018 Yamaha YZ 250f Chain Replacement: passo 4, immagine 2 di 3 2018 Yamaha YZ 250f Chain Replacement: passo 4, immagine 3 di 3
    • Use pliers to remove the safety clip from the master-link.
    • If the clip is worn it may break.
  5. 2018 Yamaha YZ 250f Chain Replacement: passo 5, immagine 1 di 1
    • Use a grinder to remove both rivets on the master-link.
    • If using a chain break, ignore this step.
    • Using a grinder can be dangerous. Ensure you are wearing eye protection and are not near any flammables.
  6. 2018 Yamaha YZ 250f Chain Replacement: passo 6, immagine 1 di 3 2018 Yamaha YZ 250f Chain Replacement: passo 6, immagine 2 di 3 2018 Yamaha YZ 250f Chain Replacement: passo 6, immagine 3 di 3
    • Use a mallet and flathead screw driver to pry off the master-link side plate.
    • Remove the master link.
  7. 2018 Yamaha YZ 250f Chain Replacement: passo 7, immagine 1 di 1
    • Remove the chain from the sprockets.
  8. 2018 Yamaha YZ 250f Chain Replacement: passo 8, immagine 1 di 2 2018 Yamaha YZ 250f Chain Replacement: passo 8, immagine 2 di 2
    • Use a 30mm socket and breaker bar to loosen the rear axle nut.
  9. 2018 Yamaha YZ 250f Chain Replacement: passo 9, immagine 1 di 1
    • Use a 10mm and 12mm wrench to loosen the axle blocks.
  10. 2018 Yamaha YZ 250f Chain Replacement: passo 10, immagine 1 di 1
    • Slide the axle blocks so that it is on the center mark of the swing-arm.
    • Centering the axle blocks will allow for the maximum life of the chain.
  11. 2018 Yamaha YZ 250f Chain Replacement: passo 11, immagine 1 di 1
    • Remove the new chain and master-link components from the package.
  12. 2018 Yamaha YZ 250f Chain Replacement: passo 12, immagine 1 di 1
    • Roll the new chain onto the sprockets until both open ends rest on top of the rear sprocket.
    • The chain will contain extra links depending on the size of the sprockets used.
    • There should be minimal slack, and no gaps between teeth on the rear sprocket.
    • Place a mark on the extra links which will be removed.
  13. 2018 Yamaha YZ 250f Chain Replacement: passo 13, immagine 1 di 2 2018 Yamaha YZ 250f Chain Replacement: passo 13, immagine 2 di 2
    • Take the chain off of the bike and use a grinder or chain-break to remove the extra unwanted links.
    • Before cutting, make sure that you have marked the proper amount of links to be removed. Once the chain is cut this cannot be undone.
  14. 2018 Yamaha YZ 250f Chain Replacement: passo 14, immagine 1 di 3 2018 Yamaha YZ 250f Chain Replacement: passo 14, immagine 2 di 3 2018 Yamaha YZ 250f Chain Replacement: passo 14, immagine 3 di 3
    • Place the chain back on the dirt bike and roll it until both open ends are on top of the rear sprocket.
    • Insert master-link into the chain from the inside out.
    • Install side plate to master-link.
  15. 2018 Yamaha YZ 250f Chain Replacement: passo 15, immagine 1 di 2 2018 Yamaha YZ 250f Chain Replacement: passo 15, immagine 2 di 2
    • Use pliers to install the safety clip onto the master-link.
    • The open end of the safety clip should be opposite the direction of wheel rotation when moving forward.
    • If safety clip is not installed properly it may cause the chain to fall off while operating.
  16. 2018 Yamaha YZ 250f Chain Replacement: passo 16, immagine 1 di 3 2018 Yamaha YZ 250f Chain Replacement: passo 16, immagine 2 di 3 2018 Yamaha YZ 250f Chain Replacement: passo 16, immagine 3 di 3
    • Once axle blocks are in the correct position, tighten the rear axle using the 30mm socket and breaker bar.
    • Use the 10mm and 12mm wrench to tighten the axle blocks.
    • Ensure there is a small amount of slack in the chain. The 3 finger method displayed is a good rule of thumb when determining chain slack.
    • Check to make sure wheel spins freely with new chain installed.
  17. 2018 Yamaha YZ 250f Chain Replacement: passo 17, immagine 1 di 1
    • Chain replacement is complete!
    • Make sure to check regularly for wear and make adjustments to the chain.
Conclusione
By following the steps provided in this guide, you will have completed a chain replacement on a 2018 YZ 250f dirtbike.
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 68
Tutti i Tempi: 2,321
