Salta al contenuto principale
2018 Honda Civic LX Engine Air Filter Replacement
Cosa ti serve
  1. 2018 Honda Civic LX Engine Air Filter Replacement, Engine Air Filter: passo 1, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement, Engine Air Filter: passo 1, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement, Engine Air Filter: passo 1, immagine 3 di 3
    • Locate the hood release latch under the dash on the driver’s side.
    • Pull on the release latch towards you to release the hood.
    Chiedi a FixBot
    Aggiungi Commento
  2. 2018 Honda Civic LX Engine Air Filter Replacement: passo 2, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 2, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 2, immagine 3 di 3
    • Locate the tab found on the front of your vehicle.
    • Sliding your hand under your hood, feel for the latch and release the tab.
    • Lift the hood once the tab is released.
    Chiedi a FixBot
    Aggiungi Commento
  3. 2018 Honda Civic LX Engine Air Filter Replacement: passo 3, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 3, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 3, immagine 3 di 3
    • Hold your hood up with one hand and locate the hood support rod.
    • Pull the hood support rod off the clip and insert the tip into the hole on the top left part of your inner hood.
    • The hood should rest on the support rod on its own; you can now remove the hand that was initially supporting the hood.
    Chiedi a FixBot
    Aggiungi Commento
  4. 2018 Honda Civic LX Engine Air Filter Replacement: passo 4, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 4, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 4, immagine 3 di 3
    • Now, look at your engine and towards the bottom right to locate the air box.
    • This plastic box contains your air filter, so we must get inside!
    • Locate the clips that hold the air box in place.
    Chiedi a FixBot
    Aggiungi Commento
  5. 2018 Honda Civic LX Engine Air Filter Replacement: passo 5, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 5, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 5, immagine 3 di 3
    • Unlatch the left and right-hand side snaps holding your box in place.
    • A simple flick downward should be enough to unclip the snaps.
    Chiedi a FixBot
    Aggiungi Commento
  6. 2018 Honda Civic LX Engine Air Filter Replacement: passo 6, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 6, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 6, immagine 3 di 3
    • Now, lift the unlatched air box with an upward pull.
    Chiedi a FixBot
    Aggiungi Commento
  7. 2018 Honda Civic LX Engine Air Filter Replacement: passo 7, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 7, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 7, immagine 3 di 3
    • Locate your old air filter found inside the air box.
    • Remove the old, dirty filter from the housing.
    Chiedi a FixBot
    Aggiungi Commento
  8. 2018 Honda Civic LX Engine Air Filter Replacement: passo 8, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 8, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 8, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    • Your now empty air box will contain dirt and debris that we remove using a microfiber towel.
    Chiedi a FixBot
    Aggiungi Commento
  9. 2018 Honda Civic LX Engine Air Filter Replacement: passo 9, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 9, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 9, immagine 3 di 3
    • Replace the old filter with our new air filter.
    • The angled edge of your filter should be on the top left-hand side, and the ridge should be on the top when putting it in the air box.
    Chiedi a FixBot
    Aggiungi Commento
  10. 2018 Honda Civic LX Engine Air Filter Replacement: passo 10, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 10, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 10, immagine 3 di 3
    • Locate the plastic teeth on the left and right of the air housing.
    • Line these teeth up with the notches in the back and push them in.
    Chiedi a FixBot
    Aggiungi Commento
  11. 2018 Honda Civic LX Engine Air Filter Replacement: passo 11, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 11, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 11, immagine 3 di 3
    • Push the air box's lid down and clip the previously unlatched snaps back to secure your air box.
    Chiedi a FixBot
    Aggiungi Commento
  12. 2018 Honda Civic LX Engine Air Filter Replacement: passo 12, immagine 1 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 12, immagine 2 di 3 2018 Honda Civic LX Engine Air Filter Replacement: passo 12, immagine 3 di 3
    • Hold your hood up with one hand. Using your other hand, remove the hood support and latch the support onto the clip you previously took it off of.
    Chiedi a FixBot
    Aggiungi Commento
  13. 2018 Honda Civic LX Engine Air Filter Replacement: passo 13, immagine 1 di 1
    • Now you're all set to close up your hood!
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
By the end of this guide, you should have been able to replace your 2018 Honda Civic LX engine air filter successfully.
Fili Zavala
Membro da: 10/24/23
267 Reputazione
Una guida realizzata
CSU Los Angeles, Team 3-94, Briggs Fall 2023 Membro di CSU Los Angeles, Team 3-94, Briggs Fall 2023
CSULA-BRIGGS-F23S3G94
Membro di 1
1 guide realizzate
1Commento della guida
When should I change the filter again?
Oreyne Lang - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 11
Ultimi 7 giorni: 33
Ultimi 30 giorni: 191
Tutti i Tempi: 3,414
