Salta al contenuto principale
2018 Chevrolet Equinox Cabin Air Filter Replacement
Cosa ti serve
  1. 2018 Chevrolet Equinox Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 1 di 2 2018 Chevrolet Equinox Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 2 di 2
    • Turn off vehicle air.
    • Find the glove box on the passenger side of the vehicle.
    • Open and remove all items from the glove box.
  2. 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 2, immagine 1 di 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 2, immagine 2 di 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 2, immagine 3 di 3
    • You will see a latch on the right side of the glove box.
    • Unhook the latch by gently pulling the latch outwards from the glove box.
  3. 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 3, immagine 1 di 2 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 3, immagine 2 di 2
    • Place your hands on the sides of the glove box.
    • Tightly squeeze the sides inward, and pull the glove box forward to detach the glove box from the dashboard.
  4. 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 4, immagine 1 di 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 4, immagine 2 di 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 4, immagine 3 di 3
    • The cabin air filter box has one 7/32" screw on each side.
    • Use a 7/32" nut driver to remove these two screws.
  5. 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 5, immagine 1 di 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 5, immagine 2 di 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 5, immagine 3 di 3
    • Plastic tabs will be right beneath the screws highlighted by markups.
    • Push the tabs in on both sides of the box simultaneously.
    • Lift the lid of the box to find the old cabin air filter.
  6. 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 6, immagine 1 di 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 6, immagine 2 di 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 6, immagine 3 di 3
    • Remove the filter, and check for debris in the filter box.
  7. 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 7, immagine 1 di 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 7, immagine 2 di 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 7, immagine 3 di 3
    • Place the new filter in the filter box.
    • The filter has an arrow, as indicated by the red box. Ensure that the arrow points down when placing the filter.
  8. 2018 Chevrolet Equinox Cabin Air Filter Replacement: passo 8, immagine 1 di 1
    • Pull the lid down and press both sides to close the filter box.
    • If you hear a clicking sound, then it means that the lid is closed.
Conclusione
To reassemble your glovebox, follow these instructions in reverse order.
Allan
Membro da: 06/08/22
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 109
Tutti i Tempi: 2,836
