Salta al contenuto principale
2017 Dodge Grand Caravan Fan Resistor Replacement
Cosa ti serve
    1. 2017 Dodge Grand Caravan Fan Resistor Replacement, Radiator Fan Resistor: passo 1, immagine 1 di 1
      • Check for symptoms: fan not spinning at all speeds, engine overheating (especially in traffic). Open the under-hood fuse box (near the battery). Find the cooling fan fuse using the lid diagram or owner's manual.
      • Red: Cooling Fan Fuse
      • NOTE: Make sure the vehicle is off to prevent damage to any electrical components
      • NOTE: A blown fuse can indicate a deeper electrical problem. If a replacement fuse blows right away, stop and consult a mechanic before continuing.
      Chiedi a FixBot
      Aggiungi Commento
    2. 2017 Dodge Grand Caravan Fan Resistor Replacement: passo 2, immagine 1 di 3 2017 Dodge Grand Caravan Fan Resistor Replacement: passo 2, immagine 2 di 3 2017 Dodge Grand Caravan Fan Resistor Replacement: passo 2, immagine 3 di 3
      • Park the vehicle on a flat surface and apply the parking brake. Turn the engine off and open the hood.
      • Let the engine cool for at least 30 minutes before touching anything in the engine bay.
      • Gather your tools: 8mm socket and ratchet set with extension, 10mm wrench, work gloves, and the new replacement radiator fan resistor (matched to your vehicle year and model).
      • Pink: Radiator Fan Resistor
      • Blue: Ratchet Extension
      • Red: 10mm Wrench
      • Orange: 8mm Socket
      • Yellow: Work Gloves
      Chiedi a FixBot
      Aggiungi Commento
    3. 2017 Dodge Grand Caravan Fan Resistor Replacement: passo 3, immagine 1 di 1
      • WARNING: Always disconnect the negative terminal before working near electrical components. Skipping this risks electric shock or damage to the electrical system.
      • Using a 10mm wrench, loosen and remove the negative (-) terminal bolt from the battery. Lift the negative cable away from the terminal and tuck it to the side so it cannot accidentally touch the terminal during the repair.
      • Red: Negative Battery Terminal Bolt
      Chiedi a FixBot
      Aggiungi Commento
    4. 2017 Dodge Grand Caravan Fan Resistor Replacement: passo 4, immagine 1 di 1
      • Look into the engine bay and locate the radiator fan assembly. The radiator fan resistor is mounted on the LEFT side of the fan shroud (the black plastic housing surrounding the fan). It is a small rectangular component with two screws and a wiring harness connector attached.
      • Pink: Radiator Fan Resistor Location
      • Red: Engine
      • Blue: Battery
      • Green: Radiator
      Chiedi a FixBot
      Aggiungi Commento
    5. 2017 Dodge Grand Caravan Fan Resistor Replacement: passo 5, immagine 1 di 1
      • Locate the wiring harness connector on the resistor. Press down on the locking tab (the small plastic tab on the side of the connector) with your thumb while gripping the connector body firmly. Pull straight out — do not pull by the wires. The connector should release smoothly.
      • Blue: Wiring Harness Connector
      • WARNING: Always grip the connector body, not the wires. Pulling by the wires can snap the locking tab or damage the harness.
      • NOTE: If it does not release, make sure the locking tab is fully pressed before pulling.
      Chiedi a FixBot
      Aggiungi Commento
    6. 2017 Dodge Grand Caravan Fan Resistor Replacement: passo 6, immagine 1 di 1
      • Using your 8mm socket and ratchet with extension, remove the two mounting screws holding the resistor to the fan shroud. Tip: If the screws are rusted, apply a small amount of penetrating oil (WD-40 or PB Blaster) and wait 10 minutes before removal to avoid stripping.
      • Blue: Mounting Clip
      • Yellow: Radiator Fan Resistor
      • Pink: Engine
      Chiedi a FixBot
      Aggiungi Commento
      • Align the new resistor with the opening in the fan shroud and slide it straight in. Do not angle or force it. Once flush against the housing, thread the two 8mm screws in by hand, then tighten snug with the socket (approx. 20 in-lbs).
      • WARNING: Do NOT overtighten this can crack the plastic mounting flange.
      Chiedi a FixBot
      Aggiungi Commento
    7. 2017 Dodge Grand Caravan Fan Resistor Replacement: passo 8, immagine 1 di 1
      • Press the wiring harness connector firmly onto the new resistor. Push straight in until you hear or feel the locking tab click into place. Give the connector a gentle tug to confirm it is fully seated and locked. A loose connector is a common cause of failure after installation.
      Chiedi a FixBot
      Aggiungi Commento
    8. 2017 Dodge Grand Caravan Fan Resistor Replacement: passo 9, immagine 1 di 1
      • Reattach the negative (-) battery cable to the battery terminal and tighten the bolt with your 10mm wrench. Close the hood, then start the engine and allow it to warm up to normal operating temperature.
      • Red: Negative Terminal
      • NOTE: If the fan still does not spin or the engine overheats: confirm the connector is fully seated, the fuse is intact, and the part number matches. If all three check out and the fan still fails, the fan motor itself may need replacement.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
After completing the repair, start the engine and let it warm up to normal operating temperature. Watch the radiator fan — it should spin up automatically as the engine heats up, with the fan running at varying speeds depending on temperature. The dashboard temperature gauge should stay in the normal range. If the fan still does not operate correctly, use the diagnostic flow chart below:
Fan works → Success!
Fan does not work → Check that the connector is fully seated
Fan still does not work → Check the cooling fan fuse
Fan still does not work → The fan motor itself may need replacement
Congratulations! You have successfully replaced your radiator fan resistor.
Ryan Wasim
Membro da: 01/28/26
169 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 40
Ultimi 30 giorni: 151
Tutti i Tempi: 451
