Salta al contenuto principale
2017 Chevrolet Traverse Cabin Air Filter Replacement
Cosa ti serve
  1. 2017 Chevrolet Traverse Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 1 di 2 2017 Chevrolet Traverse Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 2 di 2
    • Open the glove compartment.
  2. 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 2, immagine 1 di 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 2, immagine 2 di 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 2, immagine 3 di 3
    • Using your fingers, twist the two fasteners counterclockwise then pull to remove them.
  3. 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 3, immagine 1 di 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 3, immagine 2 di 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 3, immagine 3 di 3
    • On the right side of the glove box, there is a damper. Pull the damper up and then out.
    • This will allow the glove box to fully extend downward.
    • To avoid damage, secure the glove compartment box with your free hand so that it does not drop when you release the damper.
  4. 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 4, immagine 1 di 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 4, immagine 2 di 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 4, immagine 3 di 3
    • Use both hands to pull down on the plastic cabin air filter cover to remove the it.
  5. 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 5, immagine 1 di 1
    • Remove the old cabin air filter and properly dispose of it.
  6. 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 6, immagine 1 di 2 2017 Chevrolet Traverse Cabin Air Filter Replacement: passo 6, immagine 2 di 2
    • Insert the new cabin air filter into the compartment.
    • Pay special attention to the directions on the cabin air filter. The writing should be facing you and the air-flow arrow should be facing downwards.
Conclusione
Hailey Valencia
Membro da: 03/01/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 69
Tutti i Tempi: 275
