Introduzione
If your 2016 Audi TT key fob is not functioning, your battery may be damaged or dead. A functioning battery allows you to start and unlock/lock your vehicle without having to use your mechanical key in the key fob. Disposal of the spent battery should be done properly. The spent battery can be handled by the mail-order service, Battery Solutions, which will recycle your spent batteries at a low cost, calculated by the pound. Also, the national chain, Batteries Plus Bulbs, will take the battery and recycle it, and they provide the service at no cost. Here are instructions to help replace your battery.
Cosa ti serve
Press both black buttons located on the sides of the bottom chrome section and pull apart.
Altre 2 persone hanno completato questa guida.
