Salta al contenuto principale
2016-2021 Honda Civic Headlight Bulb Replacement
Cosa ti serve
  1. 2016-2021 Honda Civic Headlight Bulb Replacement, Headlight Bulb: passo 1, immagine 1 di 1
    • Pull the latch near the door panel to open the hood (inside the driver's side of the vehicle).
  2. 2016-2021 Honda Civic Headlight Bulb Replacement: passo 2, immagine 1 di 1
    • Locate the headlight.
  3. 2016-2021 Honda Civic Headlight Bulb Replacement: passo 3, immagine 1 di 3 2016-2021 Honda Civic Headlight Bulb Replacement: passo 3, immagine 2 di 3 2016-2021 Honda Civic Headlight Bulb Replacement: passo 3, immagine 3 di 3
    • Unplug the connector by pushing down on the top of the tab shown and pull it apart.
    • It should disconnect easily. If there is any resistance than you need to press the tab harder.
  4. 2016-2021 Honda Civic Headlight Bulb Replacement: passo 4, immagine 1 di 2 2016-2021 Honda Civic Headlight Bulb Replacement: passo 4, immagine 2 di 2
    • Twist the bulb counterclockwise and pull bulb out.
  5. 2016-2021 Honda Civic Headlight Bulb Replacement: passo 5, immagine 1 di 2 2016-2021 Honda Civic Headlight Bulb Replacement: passo 5, immagine 2 di 2
    • Align the three tabs on the new bulb to the three spaces in the housing for the headlight bulb.
  6. 2016-2021 Honda Civic Headlight Bulb Replacement: passo 6, immagine 1 di 1
    • Insert the new bulb and twist clockwise until it clicks.
    • Avoid touching the bulb with your hands as the oil on your hands can be damaging and cause the bulb to fail prematurely.
  7. 2016-2021 Honda Civic Headlight Bulb Replacement: passo 7, immagine 1 di 1
    • Reconnect wires to the new bulb.
Conclusione
To reconnect the new bulb follow the instructions in reverse order as shown. If the bulb does not turn on make sure to shut off the car before attempting to fix the bulb.
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 110
Ultimi 30 Giorni: 551
Tutti i Tempi: 14,569
