Salta al contenuto principale
2016–2020 Honda Civic Tail Light Replacement
Cosa ti serve
    1. 2016–2020 Honda Civic Tail Light Replacement, Tail Light: passo 1, immagine 1 di 2 2016–2020 Honda Civic Tail Light Replacement, Tail Light: passo 1, immagine 2 di 2
      • Unlock and open the trunk of the car.
      • This will allow you to access the screws once it's open.
      Chiedi a FixBot
      Aggiungi Commento
    2. 2016–2020 Honda Civic Tail Light Replacement: passo 2, immagine 1 di 2 2016–2020 Honda Civic Tail Light Replacement: passo 2, immagine 2 di 2
      • On the exterior of the trunk, take notice of the bolts connected to the tail lights. You will have to work with these.
      • A #8 socket tends to work for most Civics.
      Chiedi a FixBot
      Aggiungi Commento
    3. 2016–2020 Honda Civic Tail Light Replacement: passo 3, immagine 1 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 3, immagine 2 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 3, immagine 3 di 3
      • Attach the #8 socket to the ratchet and loosen each of the bolts, twisting the ratchet in a counterclockwise direction.
      • Use your hand to secure the tail light so it doesn't fall off once the bolts are loose.
      Chiedi a FixBot
      Aggiungi Commento
    4. 2016–2020 Honda Civic Tail Light Replacement: passo 4, immagine 1 di 2 2016–2020 Honda Civic Tail Light Replacement: passo 4, immagine 2 di 2
      • Once you have removed the screws, place them somewhere safe because you will be using them to reattach the tail light.
      • If the screws are damaged, you can replace them with two new 8.0 mm Phillips screws.
      Chiedi a FixBot
      Aggiungi Commento
    5. 2016–2020 Honda Civic Tail Light Replacement: passo 5, immagine 1 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 5, immagine 2 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 5, immagine 3 di 3
      • Pull the tail light out from the rear bumper.
      • Since this could be a tight connection, do not be afraid to use some force or you may need to move it side to side to work it out of the socket.
      • When pulling it out, be careful that you don't rip it out as it is connected to several wires.
      Chiedi a FixBot
      Aggiungi Commento
    6. 2016–2020 Honda Civic Tail Light Replacement: passo 6, immagine 1 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 6, immagine 2 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 6, immagine 3 di 3
      • Once the tail light is removed, twist the light bulb connector counterclockwise to loosen and then pull it out of the socket.
      Chiedi a FixBot
      Aggiungi Commento
    7. 2016–2020 Honda Civic Tail Light Replacement: passo 7, immagine 1 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 7, immagine 2 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 7, immagine 3 di 3
      • Put on gloves and pull the bulb out.
      • Pull the bulb out with carefully as it can take some force to pull it out.
      • For replacement, a 7740 size bulb is recommended.
      Chiedi a FixBot
      Aggiungi Commento
    8. 2016–2020 Honda Civic Tail Light Replacement: passo 8, immagine 1 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 8, immagine 2 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 8, immagine 3 di 3
      • Replace the new the light bulb by pushing it back into the socket.
      • It is important to use gloves when doing this as the oils on your hands and fingers will damage the bulb and contribute to a shorter life for the bulb.
      Chiedi a FixBot
      Aggiungi Commento
    9. 2016–2020 Honda Civic Tail Light Replacement: passo 9, immagine 1 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 9, immagine 2 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 9, immagine 3 di 3
      • Reattach the tail light.
      • This won’t require much force for it to stay attached.
      Chiedi a FixBot
      Aggiungi Commento
    10. 2016–2020 Honda Civic Tail Light Replacement: passo 10, immagine 1 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 10, immagine 2 di 3 2016–2020 Honda Civic Tail Light Replacement: passo 10, immagine 3 di 3
      • Use the #8 socket to replace the bolts that secure the tail light.
      Chiedi a FixBot
      Aggiungi Commento
    11. 2016–2020 Honda Civic Tail Light Replacement: passo 11, immagine 1 di 2 2016–2020 Honda Civic Tail Light Replacement: passo 11, immagine 2 di 2
      • Lightly tighten each bolt in the clockwise direction, alternating between each one in order to avoid one misalignment.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Billy Ouattara
Membro da: 04/19/23
229 Reputazione
Una guida realizzata
UCD-MORRIS-S23S1G5 Membro di UCD-MORRIS-S23S1G5
Community
2 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 7
Ultimi 7 giorni: 57
Ultimi 30 giorni: 211
Tutti i Tempi: 4,087
