Salta al contenuto principale
2015-Present Nissan Maxima Headlight Bulb(s) Replacement
  1. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Open the Hood: passo 1, immagine 1 di 3 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Open the Hood: passo 1, immagine 2 di 3 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Open the Hood: passo 1, immagine 3 di 3
    • Pull the hood release latch located on the lower left portion of your dashboard (near the steering wheel).
    • Fully release the hood latch by moving the yellow prop bar to the left.
  2. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Disconnect Battery: passo 2, immagine 1 di 1
    • Disconnect the battery connections from the terminals using the 10 mm socket wrench.
    • Ensure that the negative (black) terminal is disconnected first.
  3. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Remove Battery Securing Clamp: passo 3, immagine 1 di 2 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Remove Battery Securing Clamp: passo 3, immagine 2 di 2
    • Remove the battery securing clamp by removing the following bolts:
    • Three 10mm bolts
    • Ensure that the battery clamp is tightly secured to the battery during reassembly. The battery should not move when shaken.
  4. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Remove the Battery: passo 4, immagine 1 di 1
    • Grabbing the battery by the handle, carefully lift it out of the vehicle.
    • The battery is heavy. Use two hands to lift if needed.
    • Ensure that the battery is facing the correct direction when reinstalled. The positive terminal will be on top and the negative terminal will be on the bottom.
  5. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Remove Plastic Covering: passo 5, immagine 1 di 2 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Remove Plastic Covering: passo 5, immagine 2 di 2
    • Using a flathead screwdriver or nonmetal pry tool, gently pry up the following clips on the plastic covering:
    • 10 plastic clips
    • Each clip is made up of two pieces. Ensure that all pieces are accounted for.
  6. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Find Driver Headlight and Remove Housing: passo 6, immagine 1 di 3 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Find Driver Headlight and Remove Housing: passo 6, immagine 2 di 3 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Find Driver Headlight and Remove Housing: passo 6, immagine 3 di 3
    • Reaching through the battery area and to the back of the driver's side headlight, find the headlight bulb.
    • Twist the bulb to remove it from the headlight housing.
    • Once free, pull the headlight and cables up to the battery area.
  7. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Disconnect Headlight Bulb: passo 7, immagine 1 di 2 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Disconnect Headlight Bulb: passo 7, immagine 2 di 2
    • Push the small tab on the wire clip to disconnect the bulb.
    • The tab is located on the side opposite of the bulb.
  8. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Install New Headlight Bulb: passo 8, immagine 1 di 2 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Install New Headlight Bulb: passo 8, immagine 2 di 2
    • Install new bulb into wire clip. A click should be felt when it is properly seated.
    • Insert the bulb back into the headlight housing.
    • The bulb will be visible inside the headlight when installed correctly.
  9. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, (Passenger Side) Remove Windshield Fluid TankTank: passo 9, immagine 1 di 1
    • Remove the plastic clip holding the washer fluid tank in place using a flathead screwdriver or nonmetal pry tool.
    • This clip is different than those from step 5. Keep it separate from the others.
    • Once free, remove the tank from the vehicle.
    • Remove and replace the passenger side bulb using the same steps as the driver's side.
  10. 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Reinstalling the Plastic Clips: passo 10, immagine 1 di 3 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Reinstalling the Plastic Clips: passo 10, immagine 2 di 3 2015-Present Nissan Maxima Headlight Bulb(s) Replacement, Reinstalling the Plastic Clips: passo 10, immagine 3 di 3
    • Before reinserting the plastic clips for the plastic cover, they must each be separated into two pieces.
    • First, install the shorter, hollow piece into the hole until it is firmly seated.
    • Then, insert longer, solid piece into the hollow piece until it firmly snaps into place.
Conclusione
To complete the repair, reassemble all parts following instructions in reverse order.
Tyler Montgomery
Membro da: 11/17/22
181 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 97
Tutti i Tempi: 1,232
