Salta al contenuto principale
2015 Toyota Highlander Cabin Air Filter Replacement
Cosa ti serve
  1. 2015 Toyota Highlander Cabin Air Filter Replacement, 2015 Toyota Highlander Cabin Air Filter: passo 1, immagine 1 di 1
    • Make sure car is off by removing key or moving it to the off position as shown.
  2. 2015 Toyota Highlander Cabin Air Filter Replacement: passo 2, immagine 1 di 2 2015 Toyota Highlander Cabin Air Filter Replacement: passo 2, immagine 2 di 2
    • Move to the passenger side of the car and open the passenger side door.
  3. 2015 Toyota Highlander Cabin Air Filter Replacement: passo 3, immagine 1 di 1
    • Open and empty the glovebox.
  4. 2015 Toyota Highlander Cabin Air Filter Replacement: passo 4, immagine 1 di 2 2015 Toyota Highlander Cabin Air Filter Replacement: passo 4, immagine 2 di 2
    • Detach the latch at the lower right-hand side of the glovebox.
    • Pull it outwards and unclip it with your finger as shown.
  5. 2015 Toyota Highlander Cabin Air Filter Replacement: passo 5, immagine 1 di 1
    • Push in both upper sides of the glovebox to unhook the stops.
    • This should cause the entire glovebox to come down and detach.
  6. 2015 Toyota Highlander Cabin Air Filter Replacement: passo 6, immagine 1 di 1
    • Remove the front plastic cover as shown. Pull on both upper tabs using your fingers.
  7. 2015 Toyota Highlander Cabin Air Filter Replacement: passo 7, immagine 1 di 1
    • Swing down the front plastic cover.
    • Unhook the tabs from both sides of the rear plastic cover and pull it out.
  8. 2015 Toyota Highlander Cabin Air Filter Replacement: passo 8, immagine 1 di 2 2015 Toyota Highlander Cabin Air Filter Replacement: passo 8, immagine 2 di 2
    • Remove the old cabin air filter from the vehicle.
    • Clean any debris found in the cabin air filter compartment.
  9. 2015 Toyota Highlander Cabin Air Filter Replacement: passo 9, immagine 1 di 1
    • Insert the new cabin air filter into the compartment.
    • Be mindful of the airflow direction arrow. The airflow arrow should point upwards as shown.
Conclusione
Prabhmeet Brar
Membro da: 10/05/21
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 51
Tutti i Tempi: 1,113
