Salta al contenuto principale
2015 Nissan Pathfinder Rear Windshield Wiper Replacement
Cosa ti serve
  1. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement, Rear Windshield Wiper: passo 1, immagine 1 di 2 2015 Nissan Pathfinder Rear Windshield Wiper Replacement, Rear Windshield Wiper: passo 1, immagine 2 di 2
    • Gently life the wiper up and away from the windshield in an upright position.
  2. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 2, immagine 1 di 2 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 2, immagine 2 di 2
    • Using your finger and thumb, lift the wiper blade upward from the base.
    • The wiper should be sticking out and away from the windshield.
  3. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 3, immagine 1 di 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 3, immagine 2 di 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 3, immagine 3 di 3
    • Locate the pivot block at the end of the wiper arm that connects to the blade.
    • Pull the blade away with adequate force to remove the blade completely.
  4. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 4, immagine 1 di 1
    • Acquire the replacement blade and remove the rubber yellow protector.
  5. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 5, immagine 1 di 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 5, immagine 2 di 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 5, immagine 3 di 3
    • Locate the thin notch in the center of the replacement blade.
    • Locate the corresponding rounded port on the wiper arm.
    • Insert the notch into the arm and push together with mild force to attach the wiper blade to the arm.
    • When attaching the wiper blade to the arm, a clicking sound should be heard to ensure it is correctly assembled.
  6. 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 6, immagine 1 di 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 6, immagine 2 di 3 2015 Nissan Pathfinder Rear Windshield Wiper Replacement: passo 6, immagine 3 di 3
    • Gently fold the blade in and lay the wiper blade and arm back down on the windshield.
Linea Traguardo
Katie
Membro da: 08/16/23
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 246
