Salta al contenuto principale
2015 Jeep Patriot Tail/ Brake Light Replacement
Cosa ti serve
  1. 2015 Jeep Patriot Tail/ Brake Light Replacement, Jeep Patriot Tail/ Brake Light Replacement: passo 1, immagine 1 di 2 2015 Jeep Patriot Tail/ Brake Light Replacement, Jeep Patriot Tail/ Brake Light Replacement: passo 1, immagine 2 di 2
    • Open the trunk and locate the fender clips.
    • These are located near the tail lights.
  2. 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 2, immagine 1 di 3 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 2, immagine 2 di 3 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 2, immagine 3 di 3
    • Use the 3/16 inch flathead screwdriver to remove the top fender clip holding the tail light on.
  3. 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 3, immagine 1 di 1
    • Remove the lower fender clip.
    • This will release the tail light so be careful.
  4. 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 4, immagine 1 di 2 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 4, immagine 2 di 2
    • Remove the tail light to expose the light bulb.
  5. 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 5, immagine 1 di 2 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 5, immagine 2 di 2
    • Twist the light bulb to remove it from the holder.
    • Replace the old bulb with the new one. make sure to twist the new bulb to secure it.
    • Do not touch the new light bulb with your bare hands as the oil from your fingers will cause it to degrade faster and possibly shatter.
  6. 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 6, immagine 1 di 2 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 6, immagine 2 di 2
    • Align the two pegs on the tail light housing with the matching holes on the car.
  7. 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 7, immagine 1 di 2 2015 Jeep Patriot Tail/ Brake Light Replacement: passo 7, immagine 2 di 2
    • Reinsert the top and bottom fender clips.
Conclusione
Yadira Vera
Membro da: 10/26/22
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 158
Tutti i Tempi: 2,358
