Salta al contenuto principale
2015-2019 Dodge Charger Tail Light Replacement
Cosa ti serve
  1. 2015-2019 Dodge Charger Tail Light Replacement, Tail Light: passo 1, immagine 1 di 1
    • Remove the rear plastic panel cover located inside the trunk by pushing the panel towards the center of the car.
  2. 2015-2019 Dodge Charger Tail Light Replacement: passo 2, immagine 1 di 2 2015-2019 Dodge Charger Tail Light Replacement: passo 2, immagine 2 di 2
    • Remove the plastic screw securing the inner lining of the trunk by pulling outwards.
    • Do not use excess force as it can damage the screw.
  3. 2015-2019 Dodge Charger Tail Light Replacement: passo 3, immagine 1 di 2 2015-2019 Dodge Charger Tail Light Replacement: passo 3, immagine 2 di 2
    • Remove the plastic pin by prying it outwards using a pry bar to free the inner lining.
    • Pull back the inner lining to gain access to the screws securing the tail lights in place.
  4. 2015-2019 Dodge Charger Tail Light Replacement: passo 4, immagine 1 di 3 2015-2019 Dodge Charger Tail Light Replacement: passo 4, immagine 2 di 3 2015-2019 Dodge Charger Tail Light Replacement: passo 4, immagine 3 di 3
    • Remove both 8 mm nuts securing the tail lights in place using an 8 mm wrench.
    • Remove the nuts carefully as they may fall between the gaps which can be difficult to reach.
  5. 2015-2019 Dodge Charger Tail Light Replacement: passo 5, immagine 1 di 1
    • Remove the connector by squeezing both sides and pulling outwards.
  6. 2015-2019 Dodge Charger Tail Light Replacement: passo 6, immagine 1 di 2 2015-2019 Dodge Charger Tail Light Replacement: passo 6, immagine 2 di 2
    • Remove the plastic cover by pulling outwards so that the tail light can slide out.
  7. 2015-2019 Dodge Charger Tail Light Replacement: passo 7, immagine 1 di 2 2015-2019 Dodge Charger Tail Light Replacement: passo 7, immagine 2 di 2
    • Grab both sides of the tail light firmly and pull it out.
  8. 2015-2019 Dodge Charger Tail Light Replacement: passo 8, immagine 1 di 1
    • Slide the replacement tail light back in firmly.
  9. 2015-2019 Dodge Charger Tail Light Replacement: passo 9, immagine 1 di 3 2015-2019 Dodge Charger Tail Light Replacement: passo 9, immagine 2 di 3 2015-2019 Dodge Charger Tail Light Replacement: passo 9, immagine 3 di 3
    • Insert the connector back to the tail light.
    • Screw the 8 mm nuts onto the bolts by hand before tightening with a 8 mm wrench.
  10. 2015-2019 Dodge Charger Tail Light Replacement: passo 10, immagine 1 di 3 2015-2019 Dodge Charger Tail Light Replacement: passo 10, immagine 2 di 3 2015-2019 Dodge Charger Tail Light Replacement: passo 10, immagine 3 di 3
    • Push the plastic pin back into the hole to secure the side inner lining.
    • Push the plastic screw back into the hole to secure the bottom inner lining.
    • Push the rear plastic panel cover back on.
  11. 2015-2019 Dodge Charger Tail Light Replacement: passo 11, immagine 1 di 1
    • Start the vehicle to test if the tail light works.
Conclusione
Repeat the same steps to replace the other tail light.
Asad Raza
Membro da: 01/17/22
217 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 140
Tutti i Tempi: 4,228
