Salta al contenuto principale
2015-2023 Ford Mustang Cabin Air Filter Replacement
Cosa ti serve
  1. 2015-2023 Ford Mustang Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 1 di 1
    • Open and empty your glove box.
  2. 2015-2023 Ford Mustang Cabin Air Filter Replacement: passo 2, immagine 1 di 1
    • Look to the right side of the glove box to find a lever. Pull up on the lever and then push it to the right. The lever should pop right off.
    • Be gentle in this step because you do not want to break this piece as it holds the glovebox in place.
  3. 2015-2023 Ford Mustang Cabin Air Filter Replacement: passo 3, immagine 1 di 2 2015-2023 Ford Mustang Cabin Air Filter Replacement: passo 3, immagine 2 di 2
    • With a hand on either side, push inward from the sides of the glovebox. This will allow the glovebox to fall down completely, giving us access to the cabin air filter.
  4. 2015-2023 Ford Mustang Cabin Air Filter Replacement: passo 4, immagine 1 di 2 2015-2023 Ford Mustang Cabin Air Filter Replacement: passo 4, immagine 2 di 2
    • Lift up the little flap and look closely, you will see a little T20 Torx screw that is holding the air filter cover in place.
  5. 2015-2023 Ford Mustang Cabin Air Filter Replacement: passo 5, immagine 1 di 1
    • Get your T20 Torx screwdriver and remove the screw.
    • Due to the limited space, it may be difficult to use the screwdriver. I found that you can pass the screwdriver from the bottom of the glove box where one's feet would be in the passenger seat.
    • To remove a screw, remember to twist to the left, and to tighten a screw, twist to the right.
  6. 2015-2023 Ford Mustang Cabin Air Filter Replacement: passo 6, immagine 1 di 2 2015-2023 Ford Mustang Cabin Air Filter Replacement: passo 6, immagine 2 di 2
    • Gently pull down on the cover to reveal the air filter.
    • Gently remove the cabin air filter and put in your new one.
    • Pay attention to how your air filter comes out. This is important so that you know which way to put in your new air filter.
Conclusione
Mike Estrada
Membro da: 11/28/23
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 104
Tutti i Tempi: 314
