Salta al contenuto principale
2014-Present Kia Soul Brake Light Replacement
Cosa ti serve
  1. 2014-Present Kia Soul Brake Light Replacement, Brake light: passo 1, immagine 1 di 3 2014-Present Kia Soul Brake Light Replacement, Brake light: passo 1, immagine 2 di 3 2014-Present Kia Soul Brake Light Replacement, Brake light: passo 1, immagine 3 di 3
    • Open the car trunk.
  2. 2014-Present Kia Soul Brake Light Replacement: passo 2, immagine 1 di 2 2014-Present Kia Soul Brake Light Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the four 20.0 mm screws from the tail light assembly.
  3. 2014-Present Kia Soul Brake Light Replacement: passo 3, immagine 1 di 3 2014-Present Kia Soul Brake Light Replacement: passo 3, immagine 2 di 3 2014-Present Kia Soul Brake Light Replacement: passo 3, immagine 3 di 3
    • Pull the tail light assembly off.
    • Apply a counterclockwise motion on the tail light while you are pulling it off.
    • Do not use too much force to prevent cracking the plastic lens.
  4. 2014-Present Kia Soul Brake Light Replacement: passo 4, immagine 1 di 3 2014-Present Kia Soul Brake Light Replacement: passo 4, immagine 2 di 3 2014-Present Kia Soul Brake Light Replacement: passo 4, immagine 3 di 3
    • Turn the brake light socket 1/4 counterclockwise and pull it from the tail light assembly.
    • The brake light is located at the bottom of the tail light assembly.
  5. 2014-Present Kia Soul Brake Light Replacement: passo 5, immagine 1 di 1
    • Press the light bulb down and turn it 1/4 counterclockwise.
  6. 2014-Present Kia Soul Brake Light Replacement: passo 6, immagine 1 di 1
    • Pull the light bulb out of the socket.
  7. 2014-Present Kia Soul Brake Light Replacement: passo 7, immagine 1 di 3 2014-Present Kia Soul Brake Light Replacement: passo 7, immagine 2 di 3 2014-Present Kia Soul Brake Light Replacement: passo 7, immagine 3 di 3
    • Press the new light bulb down into the socket and turn it 1/4 clockwise direction.
    • Before performing this action make sure you properly place the light bulb into the socket.
  8. 2014-Present Kia Soul Brake Light Replacement: passo 8, immagine 1 di 3 2014-Present Kia Soul Brake Light Replacement: passo 8, immagine 2 di 3 2014-Present Kia Soul Brake Light Replacement: passo 8, immagine 3 di 3
    • Follow the guide in reverse order to put the socket and the tail light assembly back.
    • Before you screw the tail light assembly back have someone press the brake paddle to see if the new light bulb turns on.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 185
Tutti i Tempi: 5,959
