Salta al contenuto principale
2014 Toyota Corolla Model L Cabin Air Filter Replacement
Cosa ti serve
  1. 2014 Toyota Corolla Model L Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 1 di 1
    • Remove all of the Items in your car's glove box.
  2. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 2, immagine 1 di 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 2, immagine 2 di 2
    • Pull the glove box damper apart from screw located on the right side of the glove box.
  3. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 3, immagine 1 di 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 3, immagine 2 di 2
    • Push the two sides of the glovebox inwards towards each other and gently bring the glovebox down all the way.
    • The glovebox will completely detach.
  4. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 4, immagine 1 di 3 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 4, immagine 2 di 3 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 4, immagine 3 di 3
    • Locate the cabin air filter which has a black cap.
    • Push the tab on the right side of the black cap and push it towards the left to remove it.
  5. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 5, immagine 1 di 1
    • Remove and replace the air filter with the arrow pointing the same direction as your last air filter which will be downwards.
    • CAUTION: Your air filter will be filled with dust, leaves, and dirt. You may want to wear a mask to not inhale these harmful items.
  6. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 6, immagine 1 di 1
    • Put the black top of the filter back into place and click it back into place.
  7. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 7, immagine 1 di 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 7, immagine 2 di 2
    • Attach the black hinges located on the bottom of the glovebox back into place.
    • Lift the glovebox back into its original position.
  8. 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 8, immagine 1 di 2 2014 Toyota Corolla Model L Cabin Air Filter Replacement: passo 8, immagine 2 di 2
    • Push the glove box damper back into the screw.
Conclusione
Victor_
Membro da: 10/25/23
184 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 110
Tutti i Tempi: 467
