Salta al contenuto principale
2014-2018 Kia Forte Cabin Air Filter Replacement
  1. 2014-2018 Kia Forte Cabin Air Filter Replacement, Cabin Air Filter: passo 1, immagine 1 di 1
    • Get into the front passenger seat and open the glovebox.
  2. 2014-2018 Kia Forte Cabin Air Filter Replacement: passo 2, immagine 1 di 2 2014-2018 Kia Forte Cabin Air Filter Replacement: passo 2, immagine 2 di 2
    • Remove the 2 circular knobs toward the back of the box (on the left and right sides) and turn them counterclockwise.
  3. 2014-2018 Kia Forte Cabin Air Filter Replacement: passo 3, immagine 1 di 1
    • Remove the arm holding the glove compartment up.
    • It is located on the outer right side of the glove box.
    • Move to the right side of the glovebox and gently pop off the black retaining arm by pulling it towards the right.
  4. 2014-2018 Kia Forte Cabin Air Filter Replacement: passo 4, immagine 1 di 2 2014-2018 Kia Forte Cabin Air Filter Replacement: passo 4, immagine 2 di 2
    • Gently lower the glovebox to the floor.
    • It should hang in the position shown.
  5. 2014-2018 Kia Forte Cabin Air Filter Replacement: passo 5, immagine 1 di 2 2014-2018 Kia Forte Cabin Air Filter Replacement: passo 5, immagine 2 di 2
    • Squeeze the two tabs on the left and right end of the black rectangular casing behind the glovebox and pull the air filter cover off.
  6. 2014-2018 Kia Forte Cabin Air Filter Replacement: passo 6, immagine 1 di 1
    • The air filter should now be exposed. Remove the air filter and replace with a new one.
    • Cabin air flows top to bottom (your old filter should be dirty on the top to illustrate this). Most filters will have an arrow on the side indicating the direction of the airflow, which would be down. Install the new filter accordingly.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 54
Ultimi 30 Giorni: 242
Tutti i Tempi: 5,129
