Salta al contenuto principale
2013 Toyota Camry Rear Brake Light Bulb Replacement
Cosa ti serve
  1. 2013 Toyota Camry Rear Brake Light Bulb Replacement, Rear Brake Light Bulb Replacement: passo 1, immagine 1 di 1
    • Be sure that your car is completely turned off.
    • Pop the trunk open.
  2. 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 2, immagine 1 di 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 2, immagine 2 di 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 2, immagine 3 di 3
    • Use a spudger to pry out the two smaller fasteners inside the trunk.
    • Push on the hook fastener to remove it.
  3. 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 3, immagine 1 di 2 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 3, immagine 2 di 2
    • Peel back the canvas on the side where you are replacing the bulb.
    • You will begin to see the cables connected to the rear light.
  4. 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 4, immagine 1 di 1
    • You will see three connections; a brake light, a turn signal light, and a parking light.
    • The one we will be replacing is the brake light bulb, the biggest connection of the three.
  5. 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 5, immagine 1 di 2 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 5, immagine 2 di 2
    • Turn the bulb counterclockwise from the outer connection portion (the black part).
    • Pull the old light bulb from its connection.
    • This may be a bit difficult to pull apart, but not tools are required.
  6. 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 6, immagine 1 di 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 6, immagine 2 di 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 6, immagine 3 di 3
    • Before handling the new light bulb, wear latex gloves or something to cover your hands. Handling the bulb with bare hands will shorten the light bulb's life span.
    • Plug the new light bulb into the connection by pushing until you hear a click.
  7. 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 7, immagine 1 di 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 7, immagine 2 di 3 2013 Toyota Camry Rear Brake Light Bulb Replacement: passo 7, immagine 3 di 3
    • Place the connection into its slot and turn it clockwise to ensure it stays in place.
    • Follow Steps 2 and 3 in reverse.
Linea Traguardo
Chris
Membro da: 11/14/22
170 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 52
Tutti i Tempi: 1,307
