Salta al contenuto principale
2013 Subaru Legacy Oil and Oil Filter Replacement
Cosa ti serve
  1. 2013 Subaru Legacy Oil and Oil Filter Replacement, Oil and Oil Filter: passo 1, immagine 1 di 2 2013 Subaru Legacy Oil and Oil Filter Replacement, Oil and Oil Filter: passo 1, immagine 2 di 2
    • Drive slowly onto ramps to prop up your Subaru Legacy.
    • Don't forget to turn on your parking break and block the rear wheels with wheel chocks or 2x4 wood blocks.
    • Align the oil pan on the Legacy with the oil pan you're using to collect the oil being drained.
    • Place newspaper around the pan to catch spatters.
  2. 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 2, immagine 1 di 3 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 2, immagine 2 di 3 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 2, immagine 3 di 3
    • Loosen the drain bolt with your 17mm socket wrench just enough to where you're able to loosen the rest by hand.
    • Remove the bolt and washer by hand to allow the oil to drain into the oil pan.
  3. 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 3, immagine 1 di 3 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 3, immagine 2 di 3 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 3, immagine 3 di 3
    • Once your Legacy is completely empty of oil, clean off the bolt and washer and tighten them by hand until you can't turn it anymore.
    • Turn the bolt another 1.5 turns with the 17mm wrench.
    • Do not over-tighten the bolt.
  4. 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 4, immagine 1 di 3 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 4, immagine 2 di 3 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 4, immagine 3 di 3
    • On a 2013 Subaru Legacy the oil filter should be by the battery. Loosen the oil filter by hand if possible. If not, use an oil wrench or a crescent wrench to loosen it.
    • Be cautious while removing the oil filter to ensure you won't spill any oil.
    • Clean the tray around the oil filter after you remove it with a paper towel.
  5. 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 5, immagine 1 di 2 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 5, immagine 2 di 2
    • Rub a little bit of the new oil you bought onto the new oil filter's gasket.
    • Screw on the new oil filter by hand until it is tight. You don't have to use the wrench to tighten the filter.
    • The type of oil filter required for your Legacy should be listed in the owner's manual.
  6. 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 6, immagine 1 di 2 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 6, immagine 2 di 2
    • Fill your car with the oil mentioned in your owner's manual.
    • The owner's manual should mention the type of oil as well as the amount needed for your engine.
  7. 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 7, immagine 1 di 2 2013 Subaru Legacy Oil and Oil Filter Replacement: passo 7, immagine 2 di 2
    • Remove the dipstick and clean it. Then reinsert it and remove it again and ensure the second dot on the end of the dipstick is touched by oil.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 28
Tutti i Tempi: 1,702
