Salta al contenuto principale
2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: passo 1, immagine 1 di 2 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: passo 1, immagine 2 di 2
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
  2. 2013 Lexus IS250 Front Dome Light Replacement: passo 2, immagine 1 di 3 2013 Lexus IS250 Front Dome Light Replacement: passo 2, immagine 2 di 3 2013 Lexus IS250 Front Dome Light Replacement: passo 2, immagine 3 di 3
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
  3. 2013 Lexus IS250 Front Dome Light Replacement: passo 3, immagine 1 di 3 2013 Lexus IS250 Front Dome Light Replacement: passo 3, immagine 2 di 3 2013 Lexus IS250 Front Dome Light Replacement: passo 3, immagine 3 di 3
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
  4. 2013 Lexus IS250 Front Dome Light Replacement: passo 4, immagine 1 di 3 2013 Lexus IS250 Front Dome Light Replacement: passo 4, immagine 2 di 3 2013 Lexus IS250 Front Dome Light Replacement: passo 4, immagine 3 di 3
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
  5. 2013 Lexus IS250 Front Dome Light Replacement: passo 5, immagine 1 di 3 2013 Lexus IS250 Front Dome Light Replacement: passo 5, immagine 2 di 3 2013 Lexus IS250 Front Dome Light Replacement: passo 5, immagine 3 di 3
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
  6. 2013 Lexus IS250 Front Dome Light Replacement: passo 6, immagine 1 di 2 2013 Lexus IS250 Front Dome Light Replacement: passo 6, immagine 2 di 2
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
  7. 2013 Lexus IS250 Front Dome Light Replacement: passo 7, immagine 1 di 3 2013 Lexus IS250 Front Dome Light Replacement: passo 7, immagine 2 di 3 2013 Lexus IS250 Front Dome Light Replacement: passo 7, immagine 3 di 3
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
  8. 2013 Lexus IS250 Front Dome Light Replacement: passo 8, immagine 1 di 1
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
Conclusione
Christian
Membro da: 10/23/23
157 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 40
Tutti i Tempi: 151
