Salta al contenuto principale
2013 Honda Civic Brake Light Replacement
Cosa ti serve
  1. 2013 Honda Civic Brake Light Replacement, Brake Light: passo 1, immagine 1 di 2 2013 Honda Civic Brake Light Replacement, Brake Light: passo 1, immagine 2 di 2
    • Ensure that the vehicle is shut off before engaging in the replacement.
    • Open the trunk by pulling the latch located on the floor of the driver’s side.
  2. 2013 Honda Civic Brake Light Replacement: passo 2, immagine 1 di 3 2013 Honda Civic Brake Light Replacement: passo 2, immagine 2 di 3 2013 Honda Civic Brake Light Replacement: passo 2, immagine 3 di 3
    • The carpet liner attached to the trunk has a total of six rivet fasteners. There are three rivet fasteners located on the edges of both the right and the left sides of the trunk.
    • Using a flathead screwdriver, remove all the rivet fasteners attached to the carpet liner.
  3. 2013 Honda Civic Brake Light Replacement: passo 3, immagine 1 di 2 2013 Honda Civic Brake Light Replacement: passo 3, immagine 2 di 2
    • Pull back the carpet liner from the walls of the trunk.
    • Locate the housing compartment for the brake light socket.
  4. 2013 Honda Civic Brake Light Replacement: passo 4, immagine 1 di 2 2013 Honda Civic Brake Light Replacement: passo 4, immagine 2 di 2
    • Remove the brake light socket from the housing compartment by turning it ¼ of a turn counterclockwise to unlock.
    • Pull the brake light socket from the housing compartment.
  5. 2013 Honda Civic Brake Light Replacement: passo 5, immagine 1 di 3 2013 Honda Civic Brake Light Replacement: passo 5, immagine 2 di 3 2013 Honda Civic Brake Light Replacement: passo 5, immagine 3 di 3
    • Remove the burned-out light bulb from the brake light socket.
  6. 2013 Honda Civic Brake Light Replacement: passo 6, immagine 1 di 2 2013 Honda Civic Brake Light Replacement: passo 6, immagine 2 di 2
    • Insert the new brake light bulb into the brake light socket.
  7. 2013 Honda Civic Brake Light Replacement: passo 7, immagine 1 di 2 2013 Honda Civic Brake Light Replacement: passo 7, immagine 2 di 2
    • Insert the brake light socket back into the housing compartment by turning it ¼ of a turn clockwise to lock.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Un commento
Tebrikler,çok güzeldi.Bagaj teli koptuğunda ve arka camlar açılmadığında ne yapmalı? Bunlarıda açıklarsanız sevinirim. Kolay gelsin..
Adnan Dondurmaci - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 90
Ultimi 30 Giorni: 380
Tutti i Tempi: 7,871
