Salta al contenuto principale
2013 Honda Accord Headlight Replacement
Cosa ti serve
  1. 2013 Honda Accord Headlight Replacement, Headlight: passo 1, immagine 1 di 3 2013 Honda Accord Headlight Replacement, Headlight: passo 1, immagine 2 di 3 2013 Honda Accord Headlight Replacement, Headlight: passo 1, immagine 3 di 3
    • Turn your vehicle off and put the emergency brake on before you begin the repair.
    • Pull the tab beside the driver side footwell to release the hood.
    • Pull the tab locking the hood upwards.
    • Pull the hood up to its maximum position.
  2. 2013 Honda Accord Headlight Replacement: passo 2, immagine 1 di 2 2013 Honda Accord Headlight Replacement: passo 2, immagine 2 di 2
    • Attach the hood strut in its designated position.
    • The headlight bulbs can be found on the left and the right of the engine bay.
  3. 2013 Honda Accord Headlight Replacement: passo 3, immagine 1 di 2 2013 Honda Accord Headlight Replacement: passo 3, immagine 2 di 2
    • The bulb is located behind the headlight and to the left of the windshield washer reservoir.
  4. 2013 Honda Accord Headlight Replacement: passo 4, immagine 1 di 2 2013 Honda Accord Headlight Replacement: passo 4, immagine 2 di 2
    • Pull the bulb out from the socket.
    • Use a prying tool at the base of the socket to detach the bulb from the holder.
  5. 2013 Honda Accord Headlight Replacement: passo 5, immagine 1 di 3 2013 Honda Accord Headlight Replacement: passo 5, immagine 2 di 3 2013 Honda Accord Headlight Replacement: passo 5, immagine 3 di 3
    • Attach the new LED bulb to the socket.
    • Don't touch the new bulb with your hands or fingers. The oil from your skin can reduce the life of the bulb or cause it to shatter.
    • Place the bulb in the holder and turn it counterclockwise.
    • Once it is firmly in place, it should not budge.
Conclusione
Tahsin
Membro da: 09/19/22
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 80
Tutti i Tempi: 2,500
