Salta al contenuto principale
2013 Dodge Charger Windshield Wiper Replacement
  1. 2013 Dodge Charger Windshield Wiper Replacement, Windshield Wipers: passo 1, immagine 1 di 3 2013 Dodge Charger Windshield Wiper Replacement, Windshield Wipers: passo 1, immagine 2 di 3 2013 Dodge Charger Windshield Wiper Replacement, Windshield Wipers: passo 1, immagine 3 di 3
    • Pull the wiper blade arm away from windshield until it is locked in place and pointing directly away from the windshield.
  2. 2013 Dodge Charger Windshield Wiper Replacement: passo 2, immagine 1 di 3 2013 Dodge Charger Windshield Wiper Replacement: passo 2, immagine 2 di 3 2013 Dodge Charger Windshield Wiper Replacement: passo 2, immagine 3 di 3
    • Rotate the wiper blade perpendicular to the wiper blade arm.
  3. 2013 Dodge Charger Windshield Wiper Replacement: passo 3, immagine 1 di 2 2013 Dodge Charger Windshield Wiper Replacement: passo 3, immagine 2 di 2
    • Pull the rigid part of the wiper blade away from the arm.
  4. 2013 Dodge Charger Windshield Wiper Replacement: passo 4, immagine 1 di 3 2013 Dodge Charger Windshield Wiper Replacement: passo 4, immagine 2 di 3 2013 Dodge Charger Windshield Wiper Replacement: passo 4, immagine 3 di 3
    • Push the wiper blade down the arm (directly toward the windshield).
    • Once the clip on the windshield wiper clears the hook on the arm, your windshield wiper is completely removed.
  5. 2013 Dodge Charger Windshield Wiper Replacement: passo 5, immagine 1 di 2 2013 Dodge Charger Windshield Wiper Replacement: passo 5, immagine 2 di 2
    • Position the new blade so the hook is pointing at the wiper attachment.
    • The hook will go over the top of the attachment.
  6. 2013 Dodge Charger Windshield Wiper Replacement: passo 6, immagine 1 di 3 2013 Dodge Charger Windshield Wiper Replacement: passo 6, immagine 2 di 3 2013 Dodge Charger Windshield Wiper Replacement: passo 6, immagine 3 di 3
    • Pull the blade down toward the end of the arm until it passes the hook.
    • Push the blade up into the hook until you hear a click. This tells you that the wiper is into position.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Noah Young
Membro da: 10/23/20
187 Reputazione
1 Guida realizzata
Texas Tech, Team S9-G1, Cowan Fall 2020 Membro di Texas Tech, Team S9-G1, Cowan Fall 2020
TTU-COWAN-F20S9G1
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 26
Tutti i Tempi: 589
